Need some help with sidewall being ripped from pothole...
Yeah, I posted the wrong link. I like the Conti, but the Bridgestone is great as well.
Still, if you'll even notice $700 coming out of your bank account, I feel like you're driving the wrong car. Just my opinion.
No, I'm on your page, definitely don't replace one of those trash Turanza's with a new one. I was just saying if they are close anyway, just buy new tires.
On this car I expect to pay $900 (includes alignment) for tires every 15,000 miles. I may get away with more or less mileage, but really, it doesn't matter. The lack of other expensive service on the car makes it more than worth it. I also don't drive that much, maybe 8000 miles a year, so no big deal.
Yup, exactly what I'm thinking of doing now, $850 installed isn't too bad, still struggling between the Potenzas and the PS AS3+ though. The reason why I replaced just 1 Turanza half a year back was the other 3 were fine on their treadwear, didn't know they wear that fast. (Any idea why they are so expensive with the performance they have?)
This is minus the $160 plugs and 2hrs labor to put them in.
OPERATION: MMENU 60K Miles or 72 Months A/T 2WD
M883989 Air Conditioning Cabin Filter, Front, r&r (If Equipped)
14/19 Value High Perf Act Charcoal
MBAS Clean & Apply Battery Terminal Corrosion Protectant
MBCLK Lubricate Brake Caliper Slide Pins
MBPTRR Measure Brake Pad Thickness & Rotor Runout
MCDFM Check Installation Of Drivers Floor Mat
MCUHF Check All Under Hood Fluids
MFIC Clean Throttle Body & add Decarb Treatment to Fuel
MFTCG Fuel Tank Cap Gasket, r&r
MIBJDC Inspect Ball Joints & Dust Covers
MIDSB Inspect Drive/Axle Shaft Boots
MIEPM Inspect Exhaust Pipes & Mountings
MIEVA Inspect Valve Clearances(audible insp)
MISLB Inspect Steering Linkage & Boots
MLDHL Lube Door Hinges & Latches
MPCV PCV Valve, r&r
MRBF Replace Brake Fluid
MRESETLT Reset Service Maintenance Required Light
MRSKB Replace Smart Key Battery
MRTV Road Test Vehicle
MSRD Service Rear Differential
MSYNOILROT OIL & FILTER CHANGE / NO ROTATE
MTNBC Tighten Nuts & Bolts On Chassis (See SMG/WMG/WSG)
MWBR Front Wiper Blade Refill, r&r
MWSHFLD Check and Top Off Washer Fluid
QTY PART NUMBER PART DESCRIPTION PART PRICE EXT PRICE
1 LE87139-YZZ38 ELEMENT, AIR REFINER 45.22 45.22
1 LE00000-BATTK-IT BATT CLEAN KIT 0.29 0.29
2 LE47769-50010 BUSH, CYLINDER SLIDE 2.07 4.14
1 LE00000-MX231-2NS 2PT DECARB KIT 25.50 25.50
1 LE77316-06070 GASKET, FUEL TANK CA 25.53 25.53
1 LE12204-31050 VALVE SUB-ASSY, VENT 11.74 11.74
2 LE00475-1BF03 BRAKE FLUID 7.29 14.58
1 LE89745-50020 BATTERY, TRANSMITTER 3.80 3.80
2 LE12157-10010 GASKET, DRAIN PLUG 2.91 5.82
2 LE00000-GEARO-IL 75-90 SYN GEAR 14.46 28.92
1 LE04152-YZZA3 REPLACEABLE ELEMENT 8.26 8.26
1 LE90430-12031 GASKET 2.04 2.04
7 LE00279-0WQTE-01 0W20-SINGLE QUART (W 9.84 68.88
1 LE85214-33180 RUBBER, WIPER BLADE 11.88 11.88
1 LE85214-06140 RUBBER, WIPER BLADE 11.10 11.10
1 LE00000-WASHE-RFLD WASHER FLUID 1.75 1.75
LABOR $: 649.46
PARTS $: 269.45
GOG $: 0.00
MISC. $: 0.00
TAX $: 22.23
SUBTOTAL $: 941.14
TOTAL LABOR $: 649.46
TOTAL PARTS $: 269.45
TOTAL GOG $: 0.00
TOTAL MISC. $: 0.00
TOTAL TAX $: 22.23
ESTIMATE TOTAL $: 941.14
MPCV PCV Valve, r&r
LABOR $: 649.46
PARTS $: 269.45
GOG $: 0.00
MISC. $: 0.00
TAX $: 22.23
SUBTOTAL $: 941.14
TOTAL GOG $: 0.00
TOTAL MISC. $: 0.00
TOTAL TAX $: 22.23
You got me as to why the Turanza is so expensive, complete trash IMO. I'm sure Lexus buys them for $5 a tire, but I would't pay much more than that for them myself.
Heck no on the OEM Turanzas. I'll either have PS AS3+ or those Potenzas put on. Tirerack.com has free shipping to my dealership and it's like 80 bucks for them to install all 4
