Windshield Washer Help
Old Oct 29, 2018 | 12:44 PM
AJU72's Avatar
AJU72
Default Windshield Washer Help
Hey guys,
So my windshield washer does not spray. You can hear the motor running and the wipers wipe like they would if it were spraying, but it won't spray out of either hole. Would anyone have any advice for me? Or does the 3is have issues with the washer that I should check? I'm out of warranty and it is a 2014 is250 base. Thanks for your help!
Old Oct 29, 2018 | 01:05 PM
Pittsy's Avatar
Pittsy
Did you check to see if there was fluid in the wiper fluid reservoir?
Old Oct 29, 2018 | 02:23 PM
SSworks's Avatar
SSworks
Queue OH crap moment.
Old Oct 31, 2018 | 07:12 PM
kr2015's Avatar
kr2015
Ha! Depends on how often you use it too. I've had instances when it takes a couple seconds for the washer fluid to come out if it's been a couple months. Maybe something blocking the spray nozzle too?
Old Nov 1, 2018 | 08:20 AM
evltwn's Avatar
evltwn
Do you have regular wiper fluid in the reservoir or just water? If it's just water you could have some built up deposits at the end of the nozzle. How do they look? Make sure they aren't crusted over. Maybe take a toothbrush and try cleaning the spray nozzles. Hope this helps.
Old Feb 19, 2020 | 09:20 PM
GR3Y5H3ART's Avatar
GR3Y5H3ART
sorry to bring up an Old Thread but i am having the same kind of problem except mine only happens when its COLD? i checked briefly for any kinks or knots in the line under the Hood but seems like it runs behind the Driver Side Front Fender
mines is not Fluid, its full, i tried to wipe of the 2 nozzles on the Hood but both are clear of any impediments
any ideas what could be causing this??
Old Feb 20, 2020 | 11:50 AM
Pittsy's Avatar
Pittsy
Is the fluid water or washer fluid?
If its just water, it could be frozen in the lines...
Old Feb 21, 2020 | 01:40 AM
GR3Y5H3ART's Avatar
GR3Y5H3ART
washer fluid...going to try if i can pin point what it could be
Old Feb 21, 2020 | 07:05 AM
Sasnuke's Avatar
Sasnuke
Depending on the rating of the washer fluid (-10 vs -40), it may still be frozen.
I've had summer washer fluid freeze in the winter...simply because it wasn't rated for that low of a temp...basically it's alcohol content wasn't enough.
Old Feb 29, 2020 | 01:14 PM
GR3Y5H3ART's Avatar
GR3Y5H3ART
interesting...i think i will empty whats in there now and refill with something made specific for Winter
thanks for your help!
CarlitoIS
Feb 20, 2020 10:36 AM
rohanstar
Dec 21, 2013 06:49 AM
blueflame
Automotive Care & Detailing
13
Nov 4, 2004 11:21 PM
