Winter tire size
If those are the 17X8 you should be fine.
The bolt pattern and hub size are the same for 2IS and 3IS.
Considering I have a 2IS 17" set of wheels on mine, you should be fine...although the rims I have a slightly different design of the face, but it's almost the same.
What size do you guys recommend/you're using for 2018 IS300 AWD, right now it has summer OEM staggered 225/40R18 (front) 255/35R18 (rear) rims and tires from Lexus when it was bought. And I've never done winter tire shopping for staggered before, so do I buy all 4 the same size or staggered for winter?
And also can I use my winter tires from my 2014 X1 size is 225/50/17 same all 4.
TTBomB
Dec 14, 2017 05:37 AM
