Recommended Services for 60K
Old Oct 15, 2018 | 10:48 PM
fxturbo's Avatar
fxturbo
Question Recommended Services for 60K
Hi,
I'm thinking of the following services below for 60K Service. Which one is not needed and can be put off later ? Seems a lot. Please advise.
  1. Replace Brake Fluid
  2. Replace Spark Plugs
  3. Transmission Fluid
  4. Serpentine Belt
  5. Coolant Fluid
  6. Power Steering Fluid
  7. Differential Fluid
Old Oct 16, 2018 | 07:59 AM
Flash5's Avatar
Flash5
Originally Posted by fxturbo
Hi,
  4. Serpentine Belt
  5. Coolant Fluid
I would definitely start with transmission fluid then I would do spark plugs because even if service manual says 60k you can always go a little bit longer unless you’re having issues, then I’d do brake fluid. Serpentine belt can wait if you inspect it and it looks good with no cracks or other damage. Coolant and power steering fluid you can wait a little bit I would do that whenever you have a chance and lastly the diff fluid. Just stagger when you do all of that so you don’t have to do it all at once.
Old Oct 16, 2018 | 08:29 AM
mopudding's Avatar
mopudding
Do we have timing belt or chain?
Old Oct 16, 2018 | 08:31 AM
mopudding's Avatar
mopudding
From the service manual or your opinion (if the manual doesn't mention an interval i.e. "lifetime" tranny fluid ), can you tag each item with the recommended service interval/mileage to change. The user manual has none of this info.
Old Oct 16, 2018 | 08:37 AM
Flash5's Avatar
Flash5
Tranny fluid is subjective. Most people do between 50k and 70k miles because there’s no such thing as “lifetime tranny fluid”.
Old Oct 16, 2018 | 08:38 AM
Flash5's Avatar
Flash5
The rest of the stuff should be in the service manual at certain mileage (or km) intervals.
sidwin
GX - 1st Gen (2003-2009)
Apr 30, 2021 04:00 PM
fxturbo
Apr 30, 2018 11:24 PM
aponcin
Apr 10, 2014 02:15 PM
funcrusher
12
Nov 19, 2010 09:13 AM
Jack F
Jun 29, 2009 05:11 PM
