2014 IS Fuel pump sealed plate
Old Oct 9, 2018 | 02:47 PM
andre951's Avatar
andre951
3rd Gear
Default 2014 IS Fuel pump sealed plate
My fuel tank was punctured yesterday, so Im in the process of pulling the tank to be replaced. However, the fuel pump access underneath the rear seats seems to be sealed. Unlike previous models with the 3 bolts holding it.
Is it necessary to remove from above if I plan on dropping the tank out anyways? How much harder is this going to be because of wire slack?
I would be so grateful if someone could point me in the right direction on this part. Thanks in advance for your time!
Old Oct 9, 2018 | 03:50 PM
E46CT's Avatar
E46CT
Can you remove the tank with the fuel pump attached? Why the need to remove the pump/sender first? Unplug the pump at the top then drop the tank? Either way, it seems adhesive is holding that plate down.
Here's a pic of the fuel tank that may help you.
Old Oct 9, 2018 | 05:00 PM
andre951's Avatar
andre951
3rd Gear
Thanks so much for your reply!
My reasoning was so I can drop the tank without having to wedge and try to unplug the top because of lack of wire slack. Most importantly getting it back connected would be a hassle. I was hoping someone might have done it before and had a work around.
I pulled the grommet off and can access one of the clips easy-ish.. but the other two wouldn't be possible. I suppose I'll try underneath, just unsure in the reasoning behind changing the design to make it less useful. I am a novice though.
I'm going to disassemble from the bottom and hope it's not necessary to disconnect from the top. 😄
Old Oct 10, 2018 | 04:21 PM
KYLexusMkr's Avatar
KYLexusMkr
The plates are sealed with a butyl sealant, with a spatula or other wide tipped tool you can pry them up from the body to access the connections. Then just reapply the butyl onto the plates, or you may even be able to reuse the factory again.
Old Oct 11, 2018 | 08:05 AM
E46CT's Avatar
E46CT
Oh I see.. you have no way of unplugging it from the top. I'm sure you followed the wires and didn't see a disconnect anywhere in the interior? I'd remove that plate as said and see what you can do from there. If the factory can put it in, you can pull it out.
Old Oct 11, 2018 | 06:03 PM
andre951's Avatar
andre951
3rd Gear
Thanks! This was very helpful in giving me the courage to pry the body. It seemed fragile and I didn't know how strong the adhesive was. I used a putty knife with a light hammer around to break it free enough.
I'll be cleaning it and applying a new coat once I'm reassembling.
After opening the access holes, I unplugged the connections and was able to drop the tank easily.
I'm going to need to transfer my hardware from the old tank to the new. Working on getting these retainers off now.
Thank you for the help everyone! Well on my way to getting back on the road.
Old Oct 12, 2018 | 08:08 AM
E46CT's Avatar
E46CT
"Look ma! No gas tank!"
How'd you pierce your tank btw?
bryceis250
Mar 8, 2018 01:27 PM
3tcpower
Oct 12, 2015 08:33 AM
ImWildBill
14
Mar 21, 2014 09:50 AM
crazimofo
Jun 21, 2007 11:39 PM
clean
Jun 7, 2007 04:59 PM
