2015 is250 hid bulb replacement
Old Sep 10, 2018 | 09:05 PM
Temescal's Avatar
Temescal
Default 2015 is250 hid bulb replacement
Is there any diy information for 2015 is250 hid bulb replacement
Old Sep 11, 2018 | 03:54 PM
tofuprod's Avatar
tofuprod
Assuming you do not have an FSport as the base models may have HIDs, but the F-Sports all came with LEDs standard.
Anyways, I haven't done it as we have the FSport but as typically with most cars, you can try going through the engine bay, usually by directly accessing the bulb or removing the front tray cover areas and then accessing. If that doesn't work, the next solution is to remove a wheel (or turn it to the side which is what I usually do), remove the fender guards/splash shields, and then peel it back and access the bulbs through the fenderwell.
If that doesn't work, remove your front bumper (and at times your fender) and then you for sure can access the bulb, not to mention the whole headlight assembly.
Hope this helps.
Old Sep 11, 2018 | 05:24 PM
ClubLUser's Avatar
ClubLUser
Originally Posted by tofuprod
...If that doesn't work, remove your front bumper ....
You do not need to remove the bumper...
i have the Fsport Canadian model with HID.
Just reach behind the headlight for the passenger side (remove air box first), there's a ballast for the HID bulbs that you have to remove (by twisting counter clockwise), and on the driver side you have to remove the washer fluid reservoir before getting to the back of the housing.
Old Sep 12, 2018 | 04:27 AM
tofuprod's Avatar
tofuprod
I'm not saying you need to remove the bumper, I'm saying in each step IF the prior does not work, the next step would suffice.
Old Sep 12, 2018 | 10:17 AM
Slplknight's Avatar
Slplknight
It’s a 20 minute job. Airbox remove is no problem and the washer fluid thing only need to pull.
Old Nov 5, 2024 | 04:09 PM
jorgah360's Avatar
jorgah360
1st Gear
Hope this helps.
Ive removed my bumper but idk where to access the bulb for the night time running lights there is no helpful video on this specific headlight i have a non fsport is250 hopefully you can help with this issue?
cvuplay
RX - 3rd Gen (2010-2015)
Sep 19, 2022 01:10 PM
shvc1991
Feb 2, 2017 03:52 PM
CodeRed
16
Jan 30, 2014 12:49 PM
Nat
Apr 5, 2011 08:35 PM
alexpro
Feb 3, 2010 07:24 PM
