Passenger side HID bulb not working
Old Feb 2, 2010 | 02:23 PM
alexpro's Avatar
alexpro
Default Passenger side HID bulb not working
Hi, the bulb stopped working now that I reached 50,000 miles. How does one go about replacing this bulb? I saw Gen 1 required that you remove the fender liner and the entire headlight assembly. I was able to remove the white tabbed plastic cover even though it is pretty tight in that area. I assume the assembly must be removed but I'm hoping it can be done without tampering with the bumper. Any help would be greatly appreciated. I would also like to know if anyone has purchased those lower priced HID bulbs from China advertised for about $25 each. A big difference from the Sylvania prices at the auto parts store that sell for $130.
Thanks,
Old Feb 2, 2010 | 02:55 PM
joako's Avatar
joako
See if they have the bulb you are looking for: http://www.ddmtuning.com/index.php?p...=264&parent=94
I believe it will be D1S or D2S? I have bought their complete kits before and never had a problem. They do stand behind the product they sell. I would recommend you change the bulbs in pairs so that they match.
Old Feb 2, 2010 | 05:46 PM
968racer's Avatar
968racer
From what I've seen, ballasts go bad more often that xenon bulbs. So are you sure that it's the bulb?
Old Feb 3, 2010 | 08:08 AM
alexpro's Avatar
alexpro
Hi, I'm not even yet sure it is the bulb.. I still need to verify that it is the bulb by taking the working bulb from the driver's side and plugging it into the passenger side. I want to rule out the ballast.
I just want to know how to remove the bulb...... there is nothing in the manual about it other than stating to take it back to the dealer. I spoke to my dealer and he said I may need to remove the bumper. I just would like to know the steps and if it can be done without removing the headlight assembly.
Old Feb 3, 2010 | 07:24 PM
mmlex1987's Avatar
mmlex1987
What year is your RX. Certain years were more prone to water leaking into the headlight assembly and causing ballast damage? There are many posts pertaining to your situation. I would definitely read up on ballasts, headlight computers, hid bulbs, etc.
hypervish
Jul 10, 2016 01:51 PM
J-Velocity
Sep 12, 2015 01:42 AM
slimjimtel
Sep 24, 2012 02:37 PM
GRZMNKY
Jan 6, 2012 09:14 AM
superpats
12
Feb 2, 2006 12:46 PM
