wheel choice, offset, scrub radius question
Old May 19, 2018 | 11:09 AM
RageRacerM's Avatar
RageRacerM
Default wheel choice, offset, scrub radius question
Firstly, thanks to everyone that has replied to my previous messages. I’m getting further along in what to look for in the set of wheels that’s right for me. On to the topic.
For reference, front wheel specs are 18x8 +45. I was nearly going to pull the trigger on a 18x8.5 +28 wheel but then got into reading about scrub radius. I read that people have increased their the scrub radius by 0.5 - 2 inches to enhance road feel. However, I don’t know where to find the information for our baseline stats, or if it’s possible to accurately measure and calculate it (ie: how much scrub radius our vehicle already has at stock config).
By reading about scrub radius, I also learned that a lower offset will contribute to increased inner tire wear. Something I wasn’t originally aware of... Would I be better off with a 18x9.5 +40 in front? But then the concern goes to rubbing of the control arm... I’m looking to either maintain or enhance road feel. I know tires will play a huge role, but I think offset is also important.
Coilovers would follow this. Also, no idea what tread width I’d run in the front at this point.
TLDR;
Would I be better off with 18x8.5 +28 in front or 18x9.5 +40? Car would be initially sitting on stock suspension, but with coilovers to follow. Car will be daily driven with autocross/track day 3-4 times a year.
Thanks again.
Last edited by RageRacerM; May 19, 2018 at 11:18 AM. Reason: Corrected stock offset value
Old May 19, 2018 | 07:24 PM
Solara350's Avatar
Solara350
according to your concerns, +38 front +42 rear, even with 1 inch lower you're fine, other option ! you can do +35 front and +40 rear inch lower will be fine too
Old May 20, 2018 | 07:55 PM
LexoDAV's Avatar
LexoDAV
Running a 9.5 +40 offset wheel with hit the spindle . Most owners are using 8.5 widths
mark98ls40
Oct 27, 2022 09:19 AM
ddvette9
Mar 17, 2015 09:18 AM
montz450
VIP Style
Feb 16, 2011 11:46 AM
wavesonic
Mar 19, 2005 02:43 AM
