D2 Coilovers help!!
Old May 5, 2018 | 03:54 AM
Thesickest's Avatar
Thesickest
Default D2 Coilovers help!!
hey guys I purchased a set of D2 racing coilovers and
before i install them I wanted to ask what’s the lowest I can go without affecting the performance? I have tti stage 2 but I was thinking if I go full static I won’t be able to enjoy it as much as I do now!(and I really enjoy it lol)
Also I have a set of 19” rims should I go back to 18” ? Someone told me my car my rims affect the performance as well cuz they’re too big..
Old May 5, 2018 | 06:56 PM
Sasnuke's Avatar
Sasnuke
I think your original post contains a few different elements that don't necessarily tie together.
The TTI Stage 2 tune will increase your engine performance. That's already installed, by the sound of it, so you're good there.
The larger 19 inch wheels could effect your handling positively or negatively, depending on what the setup is, but won't have impact on the engine performance...maybe overall vehicle performance, but that's about it.
The coilovers impact only the suspension, so it will effect handling. At a very extreme, the coilover setup cpuld effect the launching capability of the vehicle, but it's not like the IS's are rolling with 500+hp...so realistically the coilovers won't have any impact.
Old May 6, 2018 | 11:17 AM
Thesickest's Avatar
Thesickest
Basically what I’m trying to ask is how low can I got without scraping the ***** out of my car at 80+ mph
Old May 6, 2018 | 06:08 PM
Sasnuke's Avatar
Sasnuke
I think the answer to your question really depends on where you're driving the vehicle.
You could lower the car 2 inches and be driving in an area where the roads are good and there are little to no potholes, and you'd be perfectly fine.
Alternately, you could lower it 2 inches and be in a downtown core where the roads are terrible, and be bottoming out everywhere.
I'm not sure how the speed would really impact it bottoming out or not.
For sure lowering it an inch all around should be fine no matter where you are, but after that it's really environment and personal preference.
Old May 6, 2018 | 06:58 PM
Solara350's Avatar
Solara350
lol you're a funny guy, for Lexus IS XE30 chassis suspension ? how low can you go ? from 1 inch to 1.4 inch, if you lower than 1.8 inch on Lexus IS 3rd gen, you'll bottom out on every pothole and bump either City or Freeway with 2 persons +
You can have 19 inch rims but stay with OEM specs as close as possible or you'll be rubbing
Alternate your suspension or tires size indeed effects handling and performance, for example too big or too small tires specs, too small effects braking and handling, too big effects speed and gas mileage and definitely slow your car down
I think you're worrying about Power and Handling like me, but some people likes the nice looking, if you like perfect setup with 0 issue, here my personal reference :
With your Coilovers 1.2 inch drop in the front 1 inch drop in the rear. Wheel size 225/35/19 Offset +38 in the front . 255/30/19 offset +40 in the rear
Old May 8, 2018 | 07:24 PM
Thesickest's Avatar
Thesickest
lol I try!! These are almost the same specs I got except I got +32 in front but thanks 🙏🏽
Old May 8, 2018 | 07:45 PM
Solara350's Avatar
Solara350
im sure +38 front is perfect without issue but you can try +32 due to the least specs size that you'll have on it and the drop is minimal , i think it will be fine, as long as you have lesser than 1.8 drop and wheel specs like above.
Old May 9, 2018 | 05:53 AM
Thesickest's Avatar
Thesickest
+38 in front? I might just give it a shot since I’m getting a new set of wheels soon! I’ll keep you guys posted and post a pic once I drop and get new rims😎
Old May 9, 2018 | 06:20 AM
Sasnuke's Avatar
Sasnuke
You would still be fine with a +32 in front with a 225 tire.
JZS140
GS - 1st Gen (1993-1997)
Oct 25, 2017 09:56 AM
bfor3
Suspension
Jun 12, 2016 11:21 AM
jroy3221
Northeast
Jun 6, 2015 08:39 PM
Yamaheart
Suspension and Brakes
13
Jan 6, 2011 10:43 AM
2SAVVY
Jan 26, 2002 03:26 PM
