Remove Door Trim Plastic
Old Apr 25, 2018 | 10:09 AM
breakbeat2's Avatar
breakbeat2
Default Remove Door Trim Plastic
Does anyone know if the entire door panel has to be removed to take off the portion circled below? I know that the window control surrounding pops up, but it appears there are screws inside (hard to get to) holding the other plastic piece. I want to wrap these pieces, but it looks like they're a pita to get out. Thoughts?
Old Apr 25, 2018 | 10:16 AM
breakbeat2's Avatar
breakbeat2
I've seen 1 other user where those parts are wrapped. I haven't heard from him how he did it, but here are the pics for reference.
Old Apr 25, 2018 | 11:13 AM
Fingers007's Avatar
Fingers007
you have to remove the door panel. there's a video on youtube that shows how to do it.
Old Apr 25, 2018 | 11:28 AM
breakbeat2's Avatar
breakbeat2
Thanks fingers, trying to figure out how to access the screws from the inside part of the door. Even with the panel off, it doesn't look like here's "easy" access.
Old Apr 26, 2018 | 04:50 AM
Ciggy's Avatar
Ciggy
This is not a fun task! however it's possible.
Take the door panel off and bring it in the garage or house, and start removing screws from the back side. There are a lot of them. I removed mine and had them hydro dipped.
Take your time, some parts clip in, some parts need to be pushed out the front side after 1 or 2 it get's easier. My suggestion would be to take photos of the screws when removing them. I think they are all the same size and type but when I reassembled I ended up with 2 extra screws from 2 separate doors. Could not figure out where they went. Everything has been great so far.
I believe at some point I saw someone made an illustrations showing where most of the screws were located. I'll look around for it.
It probably took me 2 hours to remove all of the paneling and then I actually put the door panels back in the car with these parts missing. Hydro dip is not the quickest process and I wanted to drive the car. Probably took me 3 hours to reassemble after the dip was complete.
Old Apr 26, 2018 | 06:50 AM
breakbeat2's Avatar
breakbeat2
Thank you Ciggy, appreciate the confirmation!
Old Apr 27, 2018 | 08:34 AM
E46CT's Avatar
E46CT
That would be cool to wrap those pieces w/ leather. Might not fit well. that plastic looks so cheap. especially by the gear shifter. not sure why lexus chose that cheap plastic.
Old Apr 27, 2018 | 08:41 AM
breakbeat2's Avatar
breakbeat2
Yeah, they are cheap. The ones by the shifter are easy to remove. The door ones will be a pain.
Old Apr 27, 2018 | 08:53 AM
Ciggy's Avatar
Ciggy
The problem I've caused is that the hydro dip, plus clear coat made the pieces a tad bit thicker and a little bit more rigid. So on some songs the piece will vibrate a bit. I'm very sensitive to these noises so I've added some felt between the window switch piece and the door trim but I haven't solved the high pitch vibration yet...
I'm thinking if you do vinyl, or leather. You'd actually be making the door quieter which would be fantastic. If your someone who likes a quiet car you could add dynamat in the doors while you've got the panels off and really sound deaden the cabin.
I've got some work to do in the next couple weeks and then ill be doing some official photo shoots of my interior and exterior so you guys can get a good look at all the work i've done.
Try your best to count and remember where each screw belongs at the end of my project I had missed a screw from 2 different doors. Couldn't find where they belonged after everything was assembled so just through them in a baggy in the basement in case I ever disassemble the doors again. For now. Everything is gooooood.
The work really isn't difficult. Just take your time it's easy to figure out which screw is keeping you from removing the pieces.
Old Apr 27, 2018 | 11:09 AM
breakbeat2's Avatar
breakbeat2
Thumbs up
I'll remember to take pictures of the screws before i take them off. I managed to take apart my center console up to the digital clock/vents, wasn't all that difficult to do.
I'll BOLO for your pictures
Bankswood
Sep 16, 2012 12:20 PM
sightdev
RX - 3rd Gen (2010-2015)
Feb 2, 2011 05:26 PM
costanza
Jun 16, 2007 09:56 AM
JasonC
May 31, 2006 05:43 PM
costanza
Nov 7, 2005 06:38 PM
