are backup cameras swappable?
Old Apr 8, 2018 | 08:32 AM
evident's Avatar
evident
Default are backup cameras swappable?
Just curious if it's possible to swap out the physical backup camera with an aftermarket one that can provide the lines?
Old Apr 8, 2018 | 08:34 AM
caloylab's Avatar
caloylab
Default backup camera
you can but you might get an error code on the dash.
Old Apr 10, 2018 | 11:24 AM
arentz07's Avatar
arentz07
Which backup camera do you have now? I thought all the IS cameras had lines, and mine certainly does. Are you not able to turn that setting on?
Old Apr 10, 2018 | 05:07 PM
MX73's Avatar
MX73
It should be a software setting, not hardware.
Old Apr 10, 2018 | 05:26 PM
evident's Avatar
evident
the 14's don't come w/ lines. Not planning on doing anything to the IS, but just curious to do it on older vehicles to get a better / clearer image. I know the display also impacts the display but camera on my 07 RX could definitely be better.
Old Apr 10, 2018 | 05:54 PM
a1rh3adsz's Avatar
a1rh3adsz
The 14's do have lines. I think you mean the lines that move side to side when the steering wheel turns.
Old Apr 11, 2018 | 07:50 AM
Is250uw's Avatar
Is250uw
Correct on the 14’ the lines are stationary
Old Apr 11, 2018 | 11:29 AM
specONE's Avatar
specONE
Those lines that move are CANBUS driven.
There is twisted pair of canbus wires going to the factory camera. Even on the stationary lines on the 2014 there is CANBUS wires on it so it may be possible that all you need to do is swap to newer camera with the moving lines since the chance is high the camera is generating those lines.
Old Apr 14, 2018 | 04:21 PM
Answer's Avatar
Answer
You can use anything for the camera. My 2015 canadian IS didn't come with a backup camera, but the plug was in the trunk, so I bought an eBay camera and it works like a charm.
The 2014 with stationary lines is because the plug is 4 wires without the "left and right" inputs. 2015+ have 6 wires so the camera "knows" when the car is turning.
The lines are actually controlled by the camera.
cdmn
Jun 3, 2019 03:26 PM
GibbsLexus
RX - 3rd Gen (2010-2015)
24
Jan 23, 2018 12:27 PM
RookieLEX
Jun 29, 2016 02:43 PM
ddvette9
Jan 29, 2015 05:45 PM
