Has anyone installed "Front Strut Tower Bar" for 3rd Gen IS ?
Old Mar 26, 2018 | 06:40 PM
  #31
Solara350's Avatar
Solara350
Originally Posted by trinhtd
im emailing them to see what the part number is
I appreciated your time Trinh, i think ill buy the Megan Racing one and do some MOD so i won't have to remove Dust cover, ill decide this Holiday weekend,
Old Mar 26, 2018 | 06:51 PM
  #32
minhael's Avatar
minhael
Originally Posted by rocketsfan
That looks awesome! Unless I overlooked it... do you mind sharing the part number for the Tom's Strut Bar? I'd like to get one for my 18' IS350 RWD.
It's in my vivid racing link.
Old Oct 23, 2019 | 05:09 PM
  #33
scriminal's Avatar
scriminal
minhael - is your car AWD or RWD? Or do you know if that Tom's bar fits on the AWD?
Old Oct 23, 2019 | 07:29 PM
  #34
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
Body dimensions in the engine bay are the same for AWD and RWD models.
Jeff
Old Oct 23, 2019 | 07:47 PM
  #35
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
Additionally, answering some other questions that came up, yes the RC F and the 3IS RWD have the same firewall.
I suspect the RC F brace would likely be very close to fitting on a 3IS. That said, the engine cover may need some modification on the V6 models.
53692-24020 - Bracket, Brace to Firewall
94151-80841 - Nut, Firewall Bracket (Qty: 2)
53681-24010 - Brace, RH
53682-24010 - Brace, LH
91631-60816 - Bolt, Brace (Qty: 4)
90179-08241 - Nut, Brace (Qty: 6)
53607-24010 - Bracket, Brace to Shock RH (without AVS)
53683-24020 - Bracket, Brace to Shock RH (with AVS)
53608-24010 - Bracket, Brace to Shock LH (without AVS)
53684-24020 - Bracket, Brace to Shock LH (with AVS)
Jeff
Old Oct 23, 2019 | 07:52 PM
  #36
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
Looking closer at some pics, I actually suspect the intake manifold may get pretty close on the RC F one. Hard to say for sure without someone giving it a shot.
Jeff
Old Nov 29, 2020 | 03:50 PM
  #37
anakratis's Avatar
anakratis
Anyone know if the Tom's bar will fit 2017+ 350 AWD?
Old Nov 30, 2020 | 10:39 AM
  #38
Sid03SVT's Avatar
Sid03SVT
I've said it in other threads, I'll say it in this one:
A strut bar isn't going to help unless it ties to the firewall.
LCA bushings are you first move, beyond that, the rest of the bushings, the dampers and springs in this car are where the compliance/body roll comes in - the chassis itself is very stiff.
The RC-F brace, although not as pretty, is going to be significantly more functional than the blingy Toms brace - and even that increase in rigidity is going to be minimal at best and likely unperceivable (eg. if you drove two of the exact same cars down to the tires, one with the brace and one without, you wouldn't notice the difference).
Again, this car has a stiff chassis, soft suspension & bushings.
Feel free to keep going down the strut bar path though, but you should consider it an appearance mod unless it's tied to the firewall, and even then it's a minimal improvement to chassis rigidity. If chassis rigidity and handling is your goal, there is lower hanging fruit to go after.
Old Jan 28, 2021 | 02:03 PM
  #39
Tbonev5003's Avatar
Tbonev5003
2nd gear
Default Looking at purchasing Toms Racing braces
Originally Posted by Tim151
Toms racing on my 350 f sport you have to remove the covers over the avs sensors but it does fit and looks great.
Hey Tim, I had a few quick questions about this strut tower brace. i was wondering where you ordered it from to ship it to the states and I was curious if you have the rear brace installed as well or just the front. How’s the handling feel after you installed?
Old Jan 28, 2021 | 03:34 PM
  #40
redspencer's Avatar
redspencer
OG Member
Veteran: Marine Corps
A solid one piece front tower brace (not the three piece version with pivot bolts) will slightly improve chassis responsiveness from your steering inputs but it won't do much to improve handling.
A front or rear chassis under brace that ties the suspension to the subframe or chassis rails will do a better job at improving suspension geometry under cornering loads.
Old Jan 15, 2022 | 09:31 PM
  #41
Jason B's Avatar
Jason B
Will this fit on a 2021?
Old Jan 15, 2022 | 09:51 PM
  #42
specONE's Avatar
specONE
Funny you ask. I tired my Cusco strut bar today on my 2022 IS500 and it bolts on with no issue
Old Jan 16, 2022 | 09:41 AM
  #43
Joe Z's Avatar
Joe Z
Question
How was that hood clearance @specONE
Also, the same applies to the existing Intakes + Filter for the 2UR-GSE
Joe Z
Old Jan 17, 2022 | 10:47 AM
  #44
swaangin's Avatar
swaangin
Anyone who installed this, does this make a noticeable difference?
Old Jan 18, 2022 | 05:20 AM
  #45
arentz07's Avatar
arentz07
I've not installed it on my personal car, but I do have reason to believe it makes a difference. One being, a couple friends have installed them on their 2021 IS 350s and have claimed it is worth doing. The second is that I have driven a 2IS 350 with a strut bar, and, combined with coilovers, it really turned in nicely. I am sure the coils made a bigger difference but nonetheless, the steering response was really immediate.
