Back Up Light LED Swap
Old Mar 17, 2018 | 06:56 PM
IS3FDY's Avatar
IS3FDY
Default Back Up Light LED Swap
Im having trouble swapping the back up lights to LEDs in my 2018 IS350. I know for previous years this was done by removing the liner and accessing the bulb from inside the trunk. I removed the liner and removed the entire housing on the trunk but dont see anywhere to access the bulb. I dont want to start to take the housing apart to look inside without getting some feedback on here. Thanks in advance.
Old Mar 17, 2018 | 07:03 PM
minhael's Avatar
minhael
start the video near the 15 minute mark....should help you.
Old Mar 17, 2018 | 07:07 PM
IS3FDY's Avatar
IS3FDY
I saw this video before but they lights on the 2018 are different. THey are all contained within housing itself.
Old Mar 17, 2018 | 09:50 PM
minhael's Avatar
minhael
Sounds messy and a lot of work just to change the bulb....good luck man. It will be harder for others to help you since your model is so new lol.
Old Mar 18, 2018 | 03:18 AM
zhifan1's Avatar
zhifan1
Your user manual will have an exact step-by-step..
Old Mar 18, 2018 | 07:27 AM
MX73's Avatar
MX73
On the 2018 models, the reverse lights are not user replaceable. They are LED.
Old Mar 18, 2018 | 08:29 AM
zhifan1's Avatar
zhifan1
Sort of glad that my 2016 can be self-serviced... there's literally a DIY section and step by step to change the bulbs.
Old Mar 18, 2018 | 10:31 AM
Makool's Avatar
Makool
This is correct I have a 2018 and back up lights are LED.
Old Mar 18, 2018 | 06:15 PM
IS3FDY's Avatar
IS3FDY
Then I guess I won't need to change anything I had a nice set of 50W LEDs bulbs to put in too. Guess ill have to use them on another car. My LED swap is complete. All lights are now LED on the car.
Old Mar 18, 2018 | 06:49 PM
Makool's Avatar
Makool
Mind if I ask about the signal light? Are you running LEDs as well?
Old Mar 19, 2018 | 02:22 PM
E46CT's Avatar
E46CT
I went full LED as well. everything!
Lots of fun!
Old Mar 19, 2018 | 05:07 PM
Makool's Avatar
Makool
Lots of fun!
Do you mind sharing which signal LED lights are you running? I tried a pair but they were hyper flashing.
Old Mar 19, 2018 | 07:40 PM
MX73's Avatar
MX73
You will need to get a load balancer\equalizer or replace the stock flasher with a LED flasher relay.
Old Mar 22, 2018 | 09:32 AM
IS3FDY's Avatar
IS3FDY
I got these and they work perfect. No hyperflash and bright.
http://store.ijdmtoy.com/Error-Free-...s-p/20-009.htm
Old Mar 22, 2018 | 11:08 AM
Makool's Avatar
Makool
Awesome, thanks, I didn’t try these from them but other model.
Will order now.
Thanks again!!
