Alternator or Battery?
Old Jan 29, 2019 | 08:26 AM
  #31
E46CT's Avatar
E46CT
BTW don't look up lexus dealer prices. these things are pieces of junk on ebay all day long. $80 used or $150 remanned.
i'll bet under the plastic is a replaceable voltage regulator. your brushes may be worn down. anyway check it out https://www.ebay.com/itm/2014-2015-L...frcectupt=true
honestly these things look dinky. keep in mind they need good cooling so if yours are covered with leaves or blocked by debris, they'll overheat fast.
Old Feb 5, 2019 | 10:23 AM
  #32
E46CT's Avatar
E46CT
Any updates on the cause?
Old Sep 7, 2019 | 01:20 AM
  #33
1slowes250's Avatar
1slowes250
Default Low voltage
I replaced mine with a new battery as well still only seeing around 13.5... although No Matter What accessories I add it stays around 13.5 even with the stereo cranked up over 13 so the alternator is definitely still producing just not at 14 volts it may be set buy the factory and controlled by the ECU.
TurbodVq35
Aug 15, 2025 11:09 PM
beverlybee
Oct 7, 2013 07:43 PM
Skrapp
Jan 19, 2013 03:03 PM
KrazeMatik
Jan 19, 2011 09:53 PM
defrag010
May 4, 2009 08:54 PM
