Question for those that swap to winter tires...
Old Nov 12, 2017 | 12:13 PM
doodlebug's Avatar
doodlebug
Default Question for those that swap to winter tires...
Do you get an alignment each time you do a swap or is it not necessary?
Old Nov 12, 2017 | 03:09 PM
SikhSipahi's Avatar
SikhSipahi
No need for an alignment. The only time you need an alignment is when you touch the suspension or aggressive wheel setup with suspension mods.
Old Nov 13, 2017 | 05:04 AM
lexuscanuk's Avatar
lexuscanuk
Plus 1, plus 1
Old Nov 15, 2017 | 11:49 AM
Sybaritic's Avatar
Sybaritic
An alignment doesn't hurt either when you buy a new set of tires, but to swap to winters, no need to worry unless you notice something is noticeably off.
Old Nov 15, 2017 | 01:33 PM
mcomer's Avatar
mcomer
You do need to initialize the Tire Pressure Monitors or the light will stay on all winter.
Old Nov 15, 2017 | 01:40 PM
doodlebug's Avatar
doodlebug
We swapped them this weekend and I reprogrammed the tpms and reset the light. Last year I got an alignment after putting new tires on my OEM rims, I just wasn't sure if I needed to align it each time.
Thanks, all.
Old Nov 16, 2017 | 10:28 AM
Sybaritic's Avatar
Sybaritic
Thanks, all.
Is there a DIY way to program that TPMS light to come off, or does that have to be done by a stealership?
Old Nov 16, 2017 | 10:37 AM
Ciggy's Avatar
Ciggy
TPMS will turn on and off sometimes on it's own if all the tires are even and at the level you reset the sensor at. It's sort of got a mind of it's own.
In between summer/winter a few times I'd come out in the morning and the light would be on (30psi) as i drove and the tires warmed up the light would go back off.
As for winter tires, I adjusted my suspension about an inch up and swapped winter tires onto the F-sport rims. Alignment was 100% needed but only due to the suspension modifications.
Old Nov 16, 2017 | 10:41 AM
doodlebug's Avatar
doodlebug
We have the ATEQ Quickset since we swap wheels/tires on two cars twice a year. We figured it was worth the investment.
Old Nov 16, 2017 | 10:57 AM
Htony's Avatar
Htony
Not really. If you register new TPMS and pressures are OK, no need to initialize. This is what I do always and never have to touch the button.
Old Nov 16, 2017 | 12:34 PM
Jay89's Avatar
Jay89
I have an ateq quickset as well. Seems to work pretty good, but I also have a autel ts508 tpms tool to scan and program if needed. I like fancy gadgets though haha
05ls430518
Apr 30, 2018 07:05 AM
Brabusx2
Oct 24, 2013 10:53 PM
BlueES
12
Dec 28, 2011 08:26 AM
VTLexus
May 13, 2010 11:28 PM
myLexRX
Nov 24, 2009 11:25 PM
