Blinker not turning off
Old Sep 12, 2017 | 05:25 PM
Cranford72's Avatar
Cranford72
Default Blinker not turning off
I just bought a 2015 is250 that had some front end damage. I had to get it fixed then take it in to the dealership to get the computer reprogrammed. After doing that once i turn the blinker on it stays on after i complete a turn. It won't automatically cut off. I have to push up on it to cut the blinker off. Is that normal?
Old Sep 12, 2017 | 06:03 PM
Sasnuke's Avatar
Sasnuke
No it's not normal.
Does it do it in both directions? Left and right?
Was any work down to the steering wheel or column?
Old Sep 12, 2017 | 06:13 PM
Cranford72's Avatar
Cranford72
It works fine, It just doesn't cut off after I complete a turn. The front airbags had to be replace including the one in the stearing wheel.
Old Sep 12, 2017 | 06:33 PM
Sasnuke's Avatar
Sasnuke
Ok...so the left and right turn signal works, but it doesn't cancel in either direction after you make a turn in that direction?
If it doesn't cancel in either direction after a turn, then is sounds like the cancelling mechanism in the switch/column is damaged/broken.
You'll need to removed the steering wheel to inspect where the switch is located to see what the issue is.
fernicus
Nov 23, 2024 09:58 PM
Briitini
Apr 9, 2013 04:00 AM
speedflex
Jun 9, 2010 01:14 PM
CrZxDrAgOn
Oct 20, 2009 05:47 PM
