Wheel rub issue after camber arms?
Old Sep 6, 2017 | 12:29 PM
  #31
jkwiseeyes's Avatar
jkwiseeyes
Originally Posted by jkonquer
Could you post the alignment specs as well? If your front tires are only wearing then it probably is your lower control arm bushings.
sorry, lost that paper long time ago... i'm putting on new kicks soon so when I go get that alignment, I'll ask if they can provide a before and after.
*update* here is the results from alignment
Old Oct 24, 2017 | 10:13 AM
  #32
SceneAmati's Avatar
SceneAmati
Default Update...
So I finally got the SPC Camber arms to correct my inner tire wear...
so far, I don’t think I have rubbed my wheel against the fender. Hit plenty of dips and rough roads on my ride to work this morning.
Rear camber are set to -1.4 on each side. Which is way better than the -2.5 I had.
Weird thing is, it looks like my right rear wheel sticks out a little further than my left rear. Not by a lot but I notice it. Maybe the camber is slightly off from the numbers shown? Not sure but at least it hasn’t rubbed yet... at least to my knowledge.
Old Oct 24, 2017 | 02:50 PM
  #33
specONE's Avatar
specONE
This statement doesn't make sense, are you sure you do not have the numbers flipped?
-2.5 is more aggressive of camber angle vs -1.4
Old Oct 24, 2017 | 03:17 PM
  #34
SceneAmati's Avatar
SceneAmati
No... it does make sense. The original post was about me getting extreme inner tire wear due to the -2.5 camber.
I made this post to ask if others got their camber corrected, and if they started having rubbing issues.
So far, now that the wheel is more straight, I am fine.I might have issues if the car is full with people, but most of the time it's just me driving anyway.
Old Oct 24, 2017 | 04:45 PM
  #35
specONE's Avatar
specONE
Oh i see, understand now , The mention of rubbing of fender portion threw me off.
but Camber is not the reason for the tire wear you are seeing, it is toe that cause it. just have to wait and see if it really is helping in you case
Old Oct 25, 2017 | 05:06 AM
  #36
SceneAmati's Avatar
SceneAmati
Yeah, I'll see how it goes this time around with a brand new set of tires. Although, every time i have went to get an alignment, the toe was fine. The only issue the techs saw was my camber was negative. Everything else was in the acceptable spec range.
Old Jan 15, 2019 | 07:35 PM
  #37
bigal1267's Avatar
bigal1267
any updates on this issue? Going through the same thing here...
Old Jan 15, 2019 | 07:37 PM
  #38
SceneAmati's Avatar
SceneAmati
Sorry for the lack of updating but after getting the camber arms installed, I don't experience any wheel rub with my setup. Tires have been wearing pretty evenly.
saucn
Feb 17, 2016 07:30 AM
verals05
IS F (2008-2014)
16
Jan 3, 2010 10:58 PM
gs350on22s
Mar 24, 2009 05:48 PM
Lexatlast
GS - 1st Gen (1993-1997)
13
Nov 12, 2008 09:20 PM
baka_t
12
Feb 9, 2006 07:36 PM
