Hi. Will the stillen rear diffuser fit my is 300h fsport 2014? Do I need to remove the original diffuser, or is it bolt on? If not. Can I use the original is 350 diffuser?
Yes, it will fit. It's 3m double sided tape. Just clean your stock diffuser well and put it over with the stillen rear diffuser
no it will not fit a IS300h diffuser!
guys IS300h is different than IS300
OP has IS300h from different country, i.e. Hybrid variant
To the OP, The Stillen goes on top of the stock one. In your case if you have a IS300h, you will need a diffuser from IS250/350/200t etc and then install the Stillen on top of it. You'll probably also need to change your mufflers out so it does not look odd with the muffler tip cutouts with nothing sticking out of them.
ok. But what is the lexus part number for the is 350 original diffuser?
USDM part number 52169-53010
But in your case you may just want to find a use scratched up one since you will be fully covering it up and just using it as a base for the stillen one to mount onto.
