New Owner - Noise?
Old Apr 28, 2017 | 07:59 AM
curio's Avatar
curio
Default New Owner - Noise?
This week I purchased a 2014 IS250 with 20K miles. I have no problems with it, drives perfect. However, when I first start the car and then idle out of a parking lot, with windows down I can hear a clanky metal-like sound coming from below the car. I know that's not much info but I can't tell what it is. Any idea? The car drives perfect so I don't know if this is standard transmission sounds or what. Once I start speeding up, I can't hear it. I don't know if that's because it's not there, or if increased speed just makes it harder to hear. Sorry for the little info.
Old Apr 28, 2017 | 08:44 AM
arentz07's Avatar
arentz07
Is the sound in sync with the engine speed? i.e., when you press the gas does the noise speed up? Better yet, is it even a constant/repeated sound?
Old Apr 28, 2017 | 08:53 AM
JDR76's Avatar
JDR76
If it's a "clicking" sound it's the fuel injectors and it's normal.
Old Apr 28, 2017 | 11:32 AM
Crossxup11's Avatar
Crossxup11
Is this the sound you're referring to? if it is, be happy, that's the sound of a healthy engine.
Old Apr 28, 2017 | 12:52 PM
JDR76's Avatar
JDR76
It should be the same on the 250 as it's the direct injection that ticks, and both have it. The port injection doesn't come on at idle as I understand.
Old Apr 29, 2017 | 04:16 AM
Solara350's Avatar
Solara350
Go get an oil change with best Synthetic Oil, make a video and post on here, when you 1st buy used car no matter what dealer do just get yourself an oil change so you can keep track with your own maintenance record, but the vid clib that crosszz11 posted above, that's a healthy direct injection Engine sounds.
I need your own car's video before i can judge but anyways, Lexus has learnt a lot from previous IS model so i doubt your 2014 IS250 has any carbon buildup or camshaft issue, by the way welcome to Lexus Family and drive happy !
Old May 3, 2017 | 05:42 AM
curio's Avatar
curio
Thanks guys. No, it's not the healthy engine sound above. The best way I can describe it is that it sounds like a flag pole on a windy day (you know when the chain on the pole keeps clanging against the pole??). It sounds like it's coming from under the car, or near the wheels, not in the engine.
Old May 3, 2017 | 05:15 PM
lexiboi's Avatar
lexiboi
Hey peeps, can anyone confirm the engine sound for my 2017 IS 300 is completely normal?
2017 IS 300 Engine Ticking Sound:
Old May 3, 2017 | 06:03 PM
lexiboi's Avatar
lexiboi
Thanks for the reply! Appreciate it.
Old May 3, 2017 | 06:19 PM
lexiboi's Avatar
lexiboi
Originally Posted by PatrixUSA
No worries... now stop hijacking other poster's threads... (kidding ;-)
Opps! haha
Old May 3, 2017 | 08:01 PM
Solara350's Avatar
Solara350
2017 IS 300 Engine Ticking Sound: https://www.youtube.com/watch?v=hf7MnROihBU
Oh boy thats the injector noise on every D I E Engine BMW Audi same thing. tick tick tick your car is 2017 brand new ;p
Old May 4, 2017 | 04:48 PM
premier3IS's Avatar
premier3IS
does it sound like a rattle under the car near the driver side? and does it happen when you step on the gas?
Old May 6, 2017 | 11:46 AM
curio's Avatar
curio
It does sound like it's coming from the driver side, but I wouldn't describe it as a "rattle." It's more clunky than rattle. But why, do you have something in mind? I'm open to suggestions on what to look at it.
Old May 6, 2017 | 11:36 PM
premier3IS's Avatar
premier3IS
At first i thought it was the heat shield that may be causing the rattle, so I checked it and it looked fine. Took it to Lexus and they checked the vehicle out, said everything was normal. I then asked to get into another IS on the lot and see if it had the same issue... it did. Floored the gas pedal on it and you can hear the slight rattle / clunky sound.
I honestly haven't tried to diagnose it again, but from what I can tell, its just how it is lol. Take it to your dealership and have them take a look at it if you're still concerned and let us know what they say.
Old May 8, 2017 | 06:21 PM
curio's Avatar
curio
Took it into the local Lexus dealership today. It was there for a few hours before they could determine what it was. Apparently the tire pressure sensor came loose and was clanking around inside the driver side front tire. I didn't really believe them when they reported this to me over the phone. Doesn't seem like a little tire pressure sensor could make the kind of clangy sound I was hearing. It was very loud. Nevertheless, I haven't heard the clang since driving home so I guess that's what it was. They charged me $106 which wasn't bad but I was hoping my bumper to bumper warranty would've covered that. One last thing, the steering wheel seems to be slightly pulling toward the left now.
