Lowest offset possible
just need to know if it'll clear the brakes
As the offset gets smaller the concern is that the tire will rub on the fender, as the outer edge of rim gets closer to the outside of the wheel well.
For my winter tires I run 16" steel wheels on my 250 and I clear the front brakes no problem...don't know the offset though, but the steel wheel is nothing special.
If you rolled and stretched the fender already, I see no reason why the +23 won't fit.
As the offset number gets larger, then you need to worry about clearing the brakes and hitting the inner fender/suspension.
At 18" (F14), which is the stock F Sport rim diameter anyways, you can be assured it will clear the brakes from that perspective.
Here is a definition and pic that might help to visualize offset:
The offset of a wheel is the distance from the mounting surface of the wheel to the true centerline of the rim. A positive offset means the mounting surface of the wheel is positioned in front of the true centerline of the rim / tire assembly. This in effect brings the tire in to the fender well more. Conversely, a negative offset means the mounting surface of the wheel is behind the true centerline of the rim / tire assembly. This will cause the tire to stick out away from the vehicle.
Worst case if the rim is going to hit the brakes, then adding a very small spacer (maybe 5mm), will help to push the wheel assembly away from the brakes and let you keep the concave of the rim design.
18″
18×9.5 offsets from -25 to +23
18×10 offsets from -19 to +30
18×11 offsets from -6 to +43
18×12 offsets from +6 to +55
As mentioned in your other threads.
As we keep going back and forth... 18x9.5 +23 is the highest offset Forgestar can mill down to. You asked if 18x9 is available.. I sent you a link to forgestar F14 main page so you can see the width and offset ranges offered in each of their concavity profiles
Its easier if you just call in with questions. You can reach my direct line at (562)275-8268
