Replace shocks at 50k?
Hello,
So ever since I learned to drive, I've always been told to replace shocks every 50k. Since my IS is my first luxury car, do i still replace theses at 50k? I only ask this because I don't see this on my maintenance manual to either check or replace.
Thank you.
Thank you.
I've never heard anyone say shock absorbers should be replaced at any specific interval. I always thought they are replaced when they go bad. It is quite noticeable when shocks go bad in my opinion because of the sound a bad shock makes. I don't believe it'd be unsafe to drive a short distance with a bad shock either. I wouldn't worry about preventatively replacing them for safety reasons. I think they should last well north of 100,000 miles under normal driving circumstances.
Wow you guys are getting your *** busted on parts! I got both rears for $250 (Oem) and about to get the front OEM pair for $280!
Changed the rears myself in an hour....45 mins for 1st one, 15 mins on the other. You use a 17 mm combo wrench to loosen top nut while holding shock body with pipe wrench....it will snap after 4 spins...loosen bottom nut and pull it off! New one requires jacking up rear axle so top stem goes thru hole....you tighten it up...tighten bottom....plug harness back in....DONE!
You can do it! Quit getting f'ed at the stealership! Find a good indie...
