3IS 18 or 19x 9.5 width rims question
Old Nov 18, 2016 | 03:12 PM
HKL23's Avatar
HKL23
Default 3IS 18 or 19x 9.5 width rims question
Hey,
Anyone running a 18 or 19x9.5 +40 to +35 setup in the front of their 3IS without pulling or rolling fenders?
If so, what set up of tires are you running in the front?
My 3IS is lowered on RSR Down Springs.
Thank you,
Howard
Old Nov 18, 2016 | 05:46 PM
gpxluke's Avatar
gpxluke
Former Sponsor
Originally Posted by HKL23
Hey,
Thank you,
Howard
I used to run 18x9.5 ET35 all around on 265/35/18 RE71r all around and Im lowered on KW V3. No need to roll or pull front fender but front wheels are touching the front control arm when making a full turn so I would suggest go about 5mm wider just to be safe.
Old Nov 18, 2016 | 05:57 PM
HKL23's Avatar
HKL23
Hey their, awesome! I appreciate the help and reply. I'm looking into running TE37SL or CE28SL so that helps a lot that your set up before was TE's. What set up are you running now?
Thank you again for the help!
Old Nov 18, 2016 | 07:39 PM
dnasians's Avatar
dnasians
Hey,
Thank you,
Howard
19x9.5 +40 would put the inner wheel reaally close to the inside of the upper control arm. +35 is a better choice, and even with that, you shouldn't run a tire larger than 255/30/19
Old Nov 18, 2016 | 08:11 PM
gpxluke's Avatar
gpxluke
Former Sponsor
Im running staggered ZE40 now
Old Nov 18, 2016 | 10:45 PM
dnasians's Avatar
dnasians
19x8.5+33 and 19x9.5+40?
Old Nov 19, 2016 | 06:21 AM
Phamkq's Avatar
Phamkq
I am running 235/35/19x8.5 et.35 all around. No fender roll or rubbing at all.
Old Nov 19, 2016 | 09:29 AM
gpxluke's Avatar
gpxluke
Former Sponsor
19x8.5 +33 and 19x9.5 +31
Old Feb 7, 2021 | 11:09 AM
Chebawoo's Avatar
Chebawoo
What rear bumper/diffuser is that? and what's the tire and suspension setup?
Old Feb 7, 2021 | 04:49 PM
Eye's Avatar
Eye
How are the KW v3s compared to stock? Looking for a smoother than stock ride quality while lowered, and willing to compromise on performance - your thoughts?
hankxw
Mar 12, 2015 12:49 PM
chiem15
Build Threads
Jun 6, 2013 11:49 PM
cards43am
Mar 29, 2011 05:28 PM
lengnoou
Apr 19, 2009 07:21 AM
dchesanek
Mar 21, 2006 08:05 PM
