Regular tire pressure
Old Nov 11, 2016 | 08:51 PM
ayjonathan's Avatar
ayjonathan
Default Regular tire pressure
What's a regular tire pressure for yalls 3IS, it's been gettinh cold down here in Texas and my tire pressure been going down to 30-31. So I pumped it back up and now it's reading 40...
Old Nov 14, 2016 | 12:06 PM
Rebirthing's Avatar
Rebirthing
I use 36psi front, and 38 psi rear (cold) with the stock tires
Old Nov 15, 2016 | 05:56 AM
Monoshock's Avatar
Monoshock
36 all around, when cold (not driven in a few hours). This will require adjustment with the weather. the tires can easily reach 40 with highway driving. That's normal, and meaningless. Need to check when cool.
Old Nov 16, 2016 | 11:05 AM
genmaster's Avatar
genmaster
stock setting is 36, but once you drive it for a bit, they warm up and I have seen it gone to 40-41 which is normal i believe.. my car is AWD
Old Nov 16, 2016 | 08:21 PM
CarlitoIS's Avatar
CarlitoIS
Curious question. How do you guys fill up your tires? At a gas station? Man my tires (cold) are at like 29/30 right now. I need to put some air ASAP.
Old Nov 17, 2016 | 01:47 AM
faisal11ir's Avatar
faisal11ir
Specs for here 35 psi for front and 38 psi for rear.
Old Nov 17, 2016 | 04:59 PM
AIK's Avatar
AIK
i go 38 psi for all tires.
Old Nov 17, 2016 | 06:19 PM
computerwi's Avatar
computerwi
The factory recommended cold tire pressures are indicated on a label in the driver's door frame (or on the side of the door, depending on the market).
In the past decade or so, gas stations are started charging for compressor air so I've since purchased a small compressor for home use (110V, not the dinky 12V ones).
Old Nov 20, 2016 | 03:08 PM
ayjonathan's Avatar
ayjonathan
yeah man. QT Or racetrac offer free air for individuals. so whenever i need to pump air! that's the spot haha
Old Nov 20, 2016 | 03:10 PM
ayjonathan's Avatar
ayjonathan
thanks! yeah when i start up my car after a long cold night. its around 35-36 PSI. Then when i start to drive around it rises to about 39-40 psi. thought i was the only one.
Old Nov 20, 2016 | 10:06 PM
goldengame's Avatar
goldengame
I measure my AWD IS at 36 psi cold with my own pressure gauge. I found that the pressure sensors are a little bit off from each other, which is why I use my own gauge to be consistent.
kevinisbae
Dec 2, 2017 09:32 AM
Sagane
RC F (2015-present)
Jan 18, 2016 12:31 PM
IS350SWFL
Apr 30, 2015 11:34 PM
bryan11
Aug 12, 2014 06:32 PM
lex430
Wheels, Tires & Brakes Forum
14
Apr 20, 2002 09:33 PM
