Another LED turn signals for 3IS
Received 1,732 Likes
Having said that, there must be a bulb out there with the resistor built in. I have seen them for other bulb types (not turn signal bulbs), but I haven't looked too hard for the turn signal ones with the built in resistor.
Or maybe they just don't make them in this particular size.
Good point, didn't see the pic with the resistor. I just grabbed that link quickly for an example.
problem is the load resistor has to be big with heatsink so the bulb base will have to be pretty big
and then you definitely will have problem installing it everywhere
Definitely let us know. I had the same issue with my RC...all 4 corners and they hyperblink, only 2 (left them in the front) and I was good to go. If adding load resistors to the back solves the problem I may have to order some. Definitely huge improvement over the factory turn signals.
I installed a load resistor on each side at the rear and it fixed the hyper flash problem I had with the LEDs.
LEDs in question: https://store.ijdmtoy.com/No-Hyper-F...s-p/20-085.htm
Load resistors:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Just installed these they work great...
It's nice to have a plug and play but i'd go with a resistor install myself if they aren't brighter than now.
These (https://store.ijdmtoy.com/No-Hyper-F...s-p/20-085.htm) are MUCH brighter than stock. They advertise no resistor required but as I mentioned before I had to install one on each side.
I bought these and I wasn't happy with them. I have the single projector headlights (turn signal on the outside edge) and it performed worst than stock in daylight.
The ones I have are much brighter than stock
Having some problems with the resistors. I installed it using your method but without the quick connect. I wrapped the resistor cables around the yellow/green and black wires and put them back in. The resistor gets hot like it's working but still hyper flash.
Any help is appreciated!
Each LED should draw at least 0.45A + 6Ohm resistor to be able to fool the fail circuit detection. If your LED only draws 0.30A each, you still have hyberflash if using only 1 resistor/side setup.
I bought these and the manufacturer specifically called out a 50w 6oHm resistor which is what I have.
JDM ASTAR Extremely Bright PX Chipsets 7440 7441 T20 LED Bulbs ,Amber Yellow(Brightest Turn Signal Bulb on the Market)
https://www.amazon.com/dp/B00PGRGSH6/ref=cm_sw_r_cp_apa_FAXpzbHJC6Q7K
https://www.amazon.com/dp/B00PGRGSH6..._FAXpzbHJC6Q7K
You just need to measure the power draw on the bulb. If it doesn't draw at least 0.45A, you need 2 resistor/side (1 resistor/bulb). My assumption on the bulb you link is that the manuf called for 1 resistor for each bulb.
If you read my original post, you find out when/why you need 1 resistor/bulb or1 resistor/side(2 bulbs).
I was under the impression that the bulbs I purchased were the same as you guys. I got them from the link E46 had posted. Could you provide a link to your bulbs. It makes it much easier to follow instructions and get the same outcome if you provide links to what you purchased.
I will be testing the bulbs at the end of this week but I guess it's trial and error all over. Was hoping following someone else's foot steps would make this process shorter.
I've heard a lot of good things about this set. As far as having to mount it goes, you can probably get away with just having it hang
and the description: YITAMOTOR 2 X 7443 15W High Power Projector LED Bulbs Turn Signal Amber/Yellow Light 1400LM
The link on Amazon no longer work (it goes to some ****ty festoon bulb).
