NAV screen doesn't turn on
Old Oct 14, 2016 | 07:44 AM
jhardy's Avatar
jhardy
Default NAV screen doesn't turn on
I just had my 2014 is350 repaired after someone backed up into me in a parking lot. When I picked it up from the shop, the nav screen did not turn on. I tried searching the forums for similar issues. The ones I found seem to be more serious than mine because theirs did not turn on nor did the radio & a/c work. On mine, everything works; radio, Bluetooth, a/c buttons. Only, the screen just stays off. The people that did the repairs said they had to disconnect the battery during the repair process. It isn't a fuse/relay issue because they tested all of them. Hopefully it is something simple. Any ideas?
Old Oct 14, 2016 | 09:25 AM
RAMAIR's Avatar
RAMAIR
Honestly man that sucks.. I would put 100% liability on the shop that fixed your car.. Bottom line is it worked when you brought it in, it is their responsibility to make sure it works when you leave. Who knows what they did while they had the car.
Keep us posted
Old Oct 14, 2016 | 09:35 AM
jhardy's Avatar
jhardy
I plan on bringing it in to Lexus. Maybe my warranty would cover it? If not, that shop will definitely be responsible for whatever needs to be fixed. I trusted they'd get the job done with no issues because they are a very well known shop here that people bring most of their exotic cars to be serviced/maintained. Body repairs came out perfect and now this :/.
I'll definitely update with whatever I find out. Hopefully it can prevent someone else from having this problem in the future.
Old Oct 14, 2016 | 09:37 AM
jhardy's Avatar
jhardy
Originally Posted by PatrixUSA
Maybe the screen was turned off? Have you tried (assuming you have but not stated in post) pressing the RTI (Remote Touch Interface) mouse controller or home or menu buttons? If pressing RTI controller or menu/home buttons doesn't bring the screen back on from "screen off" mode, you may need to take to dealer to diagnose.
I've tried all of that. I can also use my steering controls to cycle through preset stations and switch modes (FM, Bluetooth, etc) without using the radio screen in the gauge cluster.
Old Oct 14, 2016 | 09:43 AM
JDR76's Avatar
JDR76
One of my coworkers was in a serious collision in his IS (ended up with over $20k in damage). When he finally got his car back from the shop, the nav didn't work either. He took it back into the shop and they found that they had disconnected it during the repairs (not sure why) and forgot to reconnect it, so it was an easy fix. Hopefully that's all it is in your case as well.
Old Oct 14, 2016 | 10:09 AM
jhardy's Avatar
jhardy
Do you or anyone else know if the connection is easily accessible? I'd like to give it a try right now if I wouldn't have to start removing things.
Old Oct 14, 2016 | 10:12 AM
JDR76's Avatar
JDR76
Sorry I do not know.
Old Oct 14, 2016 | 10:51 AM
jhardy's Avatar
jhardy
Not sure what was going on, but I could even hear the noises while scrolling through the menu. Figured it couldn't hurt anything, so I just disconnected the battery for approx. 20 sec to give her a reset and now it works....
Old Oct 14, 2016 | 11:17 AM
dnasians's Avatar
dnasians
wow, good job finding that out. it will help the rest of us out if this happens to us
Magellan
Feb 6, 2017 11:43 AM
VEGASRX330
NX - 1st Gen (2015-2021)
Sep 1, 2016 07:00 PM
jraiderg
May 2, 2015 05:29 PM
steveceno
May 26, 2014 05:30 AM
phish2112
Apr 27, 2006 07:59 PM
