Exhaust dripping water?
Old Oct 13, 2016 | 03:52 PM
Rtran's Avatar
Rtran
Default Exhaust dripping water?
I just recently installed Invidia exhaust and I'm noticing a lot of water dripping from my exhaust. Is this normal? or should I be concerned?
I noticed the water drips and a faint white smoke during a cold start and parked after a drive. Also when I'm decelerating I hear a pop noise?Anyone else having this same issue? any help would be greatly appreciated.
Is normal for my coolant to drip out of this hose?
Old Oct 13, 2016 | 06:14 PM
Break2's Avatar
Break2
Seems like it might be normal condensation. Maybe someone else will chime in.
Old Oct 13, 2016 | 07:12 PM
dnasians's Avatar
dnasians
99.9% of the time, it's just combination condensation.
if it smells sweet (like maple syrup) or if your exhaust includes light colored smoke (burning oil) along with the dripping water, then you're going to have a bad time.
cold start smoke is normal, your cat isn't up to operating temps yet.
downshift backfires are also normal. dshifting makes for a slightly richer exhaust; that coupled with hot headers makes for a little pop
coolant system probably should not be leaking. unless that's not coolant. does it smell sweet around the leak? it might just be condensation
Old Oct 13, 2016 | 07:13 PM
LexSense's Avatar
LexSense
Water/moisture is natural as part of the combustion by product. More noticeable on colder days.
The coolant part not too sure on that one.
Old Oct 14, 2016 | 12:33 PM
Rtran's Avatar
Rtran
Originally Posted by PatrixUSA
That is the coolant reservoir overflow hose for the radiator system. If coolant loss through overflow hose is minimal, no worries, if it increases (you notice significant pink staining in that area), have it checked out by a mechanic.
thanks I just got my car service recently at the dealer. I'm guessing they poured too much and didn't clean it afterwards.
Old Oct 14, 2016 | 12:39 PM
Rtran's Avatar
Rtran
I appreciate the input, I'm more at ease now lol. I guess I've never notice the water until the new exhaust install. I'm assuming that's why the stock exhaust is always stained.
The liquid has no smell from what I can tell, and it's clear like water.
Would adding a Invidia mid pipe stop this issue since it will remove a cat?
Old Oct 14, 2016 | 03:53 PM
Rtran's Avatar
Rtran
I just notice today that on the edge on both exhaust canister drips water? Can any other Invidia owner check if your exhaust drip water from there?
westfield
Hybrid Technology
Sep 13, 2012 12:26 AM
slickeast
May 24, 2012 06:44 PM
flyingjack
Nov 30, 2011 09:09 PM
Cully1326
Performance
Jun 20, 2009 11:07 PM
DDLexus
RX - 1st Gen (1999-2003)
29
Jul 8, 2005 02:42 PM
