Fuel range comparison
Old Aug 27, 2016 | 04:21 AM
Crossxup11's Avatar
Crossxup11
Default Fuel range comparison
Hello everyone,
Let's compare our fuel range readings at full.
IS350F AWD: 320KM range on full tank
I feel like this is pretty bad. What are your readings?
And other than driving style, what could be the cause of increased consumption?
Normal tire pressure 35-36 psi front, 36-38 back
Thanks to all
Old Aug 27, 2016 | 05:00 AM
Matroushi's Avatar
Matroushi
Around 500 km with IS350F RWD. Similar tyre pressures.
Old Aug 27, 2016 | 05:46 AM
webra's Avatar
webra
IS300h
Originally Posted by Crossxup11
Hello everyone,
Thanks to all
Old Aug 27, 2016 | 10:10 AM
Sango's Avatar
Sango
Originally Posted by webra
[deleted image]
IS300h
That hybrid!!! I think that number is higher since it seems like the display cannot go higher than 99.9 km/L. I wonder what the real values are once you drive the car drives a while.
Old Aug 27, 2016 | 10:23 AM
Fantasy332's Avatar
Fantasy332
2016 IS300 F Sport. AWD
Same Tire Pressures
I get roughly 400km full tank
Old Aug 27, 2016 | 01:17 PM
nathantse's Avatar
nathantse
2016 IS350 Fsport RWD.
Full tank ~ 370 Miles or 595 KM
Old Aug 27, 2016 | 03:29 PM
sirwawa's Avatar
sirwawa
if u do a reset and drive a very tiny amount you'll get 99.9 km/l
once you start driving more and it's calculating in real time you'll get back realistic numbers
webra's Avatar
webra
99.9 km/l Thats because it runs on electric only when pulling out of the station. I always reset the odometer at fill up to see mileage covered. Low fuel warning comes on around 850-900 kms.
Old Aug 27, 2016 | 05:40 PM
Sango's Avatar
Sango
Oh yes, I'm fully aware of that since I have a Camry Hybrid and have made 99.9 show up in a parking lot. I was just saying that because I was under the impression an image was going to show a combined average on a tank of gas, which is what I meant by realistic values. For instance, my tank average is about 14.88 km/l on that car.
Old Aug 27, 2016 | 07:09 PM
webra's Avatar
webra
i see. I get between 16.5-18.5 km/l normally.
Old Aug 27, 2016 | 07:19 PM
Sango's Avatar
Sango
Nice!! I always knew the IS Hybrid had better mileage, but was not sure how much. Unfortunately Lexus did not bring the IS Hybrid to North America.
Old Aug 28, 2016 | 06:37 PM
nayuta's Avatar
nayuta
14' IS350 FSport RWD.
Roughly 270-280 mpg total listed.
Used to be in the low 300s.
Mostly Sport+/35psi/Ark CBE
Old Aug 28, 2016 | 07:41 PM
ziggman's Avatar
ziggman
Default range
I get around 580-590km per tank
Old Aug 28, 2016 | 07:57 PM
CarlitoIS's Avatar
CarlitoIS
Is the range accurate? I remember when I first got the IS in May it used to be 400 miles to high 300s and now it's about 340 miles when I fill up.
Old Aug 29, 2016 | 07:46 AM
SnakeGT's Avatar
SnakeGT
I'm averaging around 520 to 550 km per tank 320 to 340 miles and I thought that was kinda ****ty. This is mostly normal and sports mode. Tires at 36 to 38 PSI
