Gas for 200t, does it really need premium?
Old Apr 18, 2016 | 06:17 PM
  #46
Olasek's Avatar
Olasek
Originally Posted by My0gr81
Note that AKI 87 fuel = RON 91
What is AKI?
What is RON?
Old Apr 18, 2016 | 06:32 PM
  #47
My0gr81's Avatar
My0gr81
Originally Posted by Olasek
What is AKI?
What is RON?
AKI = Anti Knock Index
RON = Research Octane Rating
Google and Wikipedia are your friends
Old Apr 18, 2016 | 10:28 PM
  #48
Olasek's Avatar
Olasek
Got it. It would mean that fueling an IS350 with 87 (gas stations in the US use AKI index) meets the manufacturer's minimum requirement of 91 RON (IS350's manual). BTW, thanks for this insight, a subtlety I overlooked.
Old Apr 19, 2016 | 11:04 AM
  #49
EJ255t's Avatar
EJ255t
Im Sorry, but this post should be deleted!!! not sure why this question gets asked so often!!
if you drove a lamborghini or ferrari would you fill it up with cheap gas, pretty sure you wouldnt. So its the same for your lexus!!!
treat your car right!!!!!!!
Old Apr 19, 2016 | 11:07 AM
  #50
litesoarer's Avatar
litesoarer
Lambo is long way from Lexus. Lol.
Old Apr 19, 2016 | 11:14 AM
  #51
EJ255t's Avatar
EJ255t
i know that, but the motor still requires premium fuel! same topic different car
Old Apr 19, 2016 | 11:47 AM
  #52
My0gr81's Avatar
My0gr81
There is no such thing as cheap gas, all gas meets some minimum standard define and enforced through regulations. It just so happens that US/Canada uses a different rating that has been marketed by the oil company as "regular" and "premium".
Look at the actual ratings, the definitions behind them and what your car's manual says about what's needed for your car. The IS needs RON 91 which is equivalent to AKI 87. Would you feel better if the gas companies rebranded AKI 87 to Premium and then AKI 91 (RON 95) to Super premium? Not going to happen, they spent way too much in convincing people that their premium is better.
BTW, this doesn't apply to AKI 85 or some of the high ethanol content gas, that is equivalent to AKI 85 and then use ethanol to boost octane rating. Now that is cheap gas, but really not gas as it's simply alcohol with some gas.
Old Apr 19, 2016 | 02:47 PM
  #53
Mike200T's Avatar
Mike200T
In Florida, we have options of 87, 89 and then a jump to 93. Based on the ratings is 93 a bit overkill? 89 should be plenty good, right?
Old Apr 19, 2016 | 02:54 PM
  #54
Olasek's Avatar
Olasek
87 should be plenty good too. Federal Trade Commission and industry pundits insist there is absolutely no benefit (besides losing a few hp) of using higher octane fuel than the minimum recommended by your car's manual.
Old Feb 6, 2025 | 07:48 PM
  #55
seanathan's Avatar
seanathan
1st Gear
Default Yes and no.
Originally Posted by Machine13
In a turbo’d car, when boosting, does compression ratio rise or stay the same? During the intake stroke more and faster compressed air is pushed in so comparing lower RPM’s to higher RPM’s, I just wonder if it’s the same 10.0:1 compression ratio stated on Lexus’ website at for example 2,000 RPM would remain the same at, say, 5000 RPM. Anyone know?
I realize this is 8 years late, but I can answer this.
The compression ratio you are describing is called Static Compression. Think of it as the engine not moving. What you’re asking about is Dynamic Compression (which is when the engine is rotating), and that can actually be much lower.
This is dictated mostly by camshaft lift and duration (how long/far the valves are open), and overlap duration (when both valves are open).
to give you an example, I put a giant Choppy drag race cam in my LS1 Camaro, and I was able to run 87 octane fuel because the dynamic compression was lower than stock. Could I have gotten more HP by tuning for more aggressive timing and using 93 octane? Absolutely. But I was a broke Engineering student, and saving that 10 bucks on a fill-up got me a chipotle burrito for dinner.
in short: compression isn’t everything - engine timing is.
Old Feb 7, 2025 | 11:25 AM
  #56
InveredMP's Avatar
InveredMP
Run 91 and nothing else, no discussion on this.
Old Feb 7, 2025 | 01:29 PM
  #57
arentz07's Avatar
arentz07
Yeah, this is an old thread, bumped for a reason that doesn't really answer the original question... closing.
abefroman
Oct 31, 2016 01:29 PM
blueridge
RX - 1st Gen (1999-2003)
Feb 16, 2009 07:55 AM
Dnelson
Nov 25, 2008 01:09 PM
NINEZeRO
Nov 9, 2008 11:14 PM
