Radio Delay
Old May 20, 2015 | 07:27 PM
P3RF's Avatar
P3RF
Default Radio Delay
Hi CL,
I recently leased a 2015 IS250 and I am very happy with it. My only gripe so far has been the radio. I came from a 2008 IS and when you sat down it it and hit the button within 2 seconds of the car turning over you would hear something. The new IS there is about a 15-20sec delay before you can listen to anything.
Can this be removed? its more of a personal preference but seems like a waste, 20 seconds I'm already out of the parking lot and I would prefer to change set my radio before I start driving.
Thanks
Old May 21, 2015 | 03:03 AM
Sefo's Avatar
Sefo
There must be some problem because Í do not register any delay when hearing radio....Its on right after the car is on...
Old May 21, 2015 | 08:02 AM
cp2's Avatar
cp2
Veteran: Air Force
yeah, this is the first I've heard of this. my beef w/ the "enfotainment" is that we can't change the stations right away. the disclaimer screen is on longer than it should be.
Old May 21, 2015 | 10:43 AM
Dalva's Avatar
Dalva
I have also an IS250 f2 2015, don't have this problem, the disclaimer screen goes off in a matter of seconds and the radio is on. Maybe you should have it checked by your dealer
Old May 21, 2015 | 11:11 AM
My0gr81's Avatar
My0gr81
The delay is from the disclaimer screen and no radio functions are available until that screen clears on its own or is acknowledge through the "continue" button. That screen does stay on longer than I would personally like, and it is not mere seconds, more like 30 seconds. Overall, I turn the car on first, then put my seatbelt on, by then the screen is just about done. For those that don't have Navigation, there is no delay as there is no disclaimer.
Old May 21, 2015 | 11:13 AM
krazykrnbo's Avatar
krazykrnbo
Yes! To replicate this, turn radio off then car off. Then later turn car on and try and turn radio on... it will not turn on till about 10-15 seconds seconds after car has been started then you can press the radio button or the power button to turn on
Old May 21, 2015 | 03:52 PM
azmojo's Avatar
azmojo
Maybe there is a difference for ML vs non-ML?
My ML system had quite a lag. My problem was always that I would have an audiobook on when I shut it off, then I get in the car with a bunch of friends and we all have to listen to 10-15s of it until I am able to switch to music.
Old May 29, 2015 | 09:44 PM
P3RF's Avatar
P3RF
Hey guys thanks for all the responses
I was hoping there was a setting that would bypass some of the delay without going to the dealer. most of the customizable settings are posted (seatbelt beep etc) and are posted online. I was hoping this might be a similar config issue.
It's worth noting that I usually use bluetooth as well. this adds another 10-15sec on top of the disclaimer to where it actually begins looking for my phone/musicplayer.
Any additional thoughts?
dbs600
Jun 23, 2024 05:52 AM
Adatia826
Jan 10, 2016 06:07 PM
BBLexus
Aug 3, 2013 09:33 AM
chewbone
May 23, 2006 11:09 AM
