Escort Live Hardwire set up Done!
Old Nov 29, 2014 | 02:15 PM
f16mobus1's Avatar
f16mobus1
Default Escort Live Hardwire set up Done!
Check it out....
A bit dirty but it's done! (was installed by Custom Sounds Austin Texas.
Old Nov 29, 2014 | 05:35 PM
sdotk's Avatar
sdotk
What exactly is escort?
Old Nov 30, 2014 | 09:31 AM
f16mobus1's Avatar
f16mobus1
It's a Police Radar detector company that manufactures different electronic detectors follow the link for more info. https://www.escortradar.com
Old Nov 30, 2014 | 05:37 PM
sbcluser's Avatar
sbcluser
F16Mobus1 - is that an Ace Combat 4 reference? (aka Mobius 1?)
And btw - nicely done with the installation. I also installed today by chance - but I did simply used the velcro on the RH side of steering wheel adjacent to console sidewall.
Old Dec 1, 2014 | 06:34 PM
f16mobus1's Avatar
f16mobus1
post a picture of your set up to see how it looks please.....
Yes sir Ace Combat 4!! but there's a twist in it.....here it goes....you'll find this interesting...
my reference goes deeper than that.....it's a combination of two names....Mobius 1 from Ace Combat 4 and Mabus (the last antichrist) according to Nostradamus' quatrains so that's how MOBUS1 WAS BORN.....
Old Dec 12, 2014 | 04:33 PM
sbcluser's Avatar
sbcluser
Here's a photo of my setup - simple and quick, although not as nice as f16mobus1. It's nicely within reach, and does not look conspicuous.
btw I am d2man from back in the ace combat days. When shatteredskies.net was up and running (up until last year, but it appears to be gone now) by grandmort, I had high scores in several missions.
Old Dec 13, 2014 | 12:44 PM
4TehNguyen's Avatar
4TehNguyen
you can make it a little cleaner than that, you can hide the wires behind that plastic trim by removing the leather part on the center console. The small piece on the bottom is my nav bypass switch. You dont need the velcro either
Old Jan 20, 2015 | 11:45 AM
rhwimmers's Avatar
rhwimmers
CL Folding 25,000
Very nice guys, looking to do this as well, what did you wire to where to get this to work? Did you use those little fuse taps and wire to the fuse box? Is your detector mounted on your left bottom of windshield - I always thought middle center mounted was ideal location?
Old Jan 20, 2015 | 03:09 PM
4TehNguyen's Avatar
4TehNguyen
i mounted mine at the bottom of the windshield to the left of the center speaker grille.
I wired to the ignition fuses in the fuse box near the pedals. I didnt use a fuse tap. I just pulled the fuse, put the wire in and put the fuse back in
verly6565
Oct 3, 2018 02:06 PM
bmaez
RX - 3rd Gen (2010-2015)
19
Aug 2, 2016 07:48 AM
Aleks1
CT 200h Model (2011-2017)
Oct 20, 2015 10:52 AM
timeToy
IS F (2008-2014)
63
Nov 21, 2012 02:12 PM
Overclocker
Apr 24, 2008 02:22 PM
