A/V Input Instructions
Old Jun 8, 2015 | 03:33 AM
  #46
gennacide's Avatar
gennacide
any luck?
if I buy some of the hdmi composite adapters and sell them on here would there be any interest?
Old Jun 8, 2015 | 05:22 PM
  #47
GiN4tHeWiN's Avatar
GiN4tHeWiN
what about for android phones? galaxy s5, etc.
Old Jun 8, 2015 | 06:58 PM
  #48
gennacide's Avatar
gennacide
do the same thing, except get the proper hdmi adapter for your phone.....
Old Jul 6, 2015 | 04:49 PM
  #49
IS3FIDY's Avatar
IS3FIDY
Gennacide can you take a pic of the connectors/set up so we can see exactly how it's supposed to be hooked up? Would be nice to get a visual reference. Thank you
Old Jul 7, 2015 | 11:08 AM
  #50
sdotk's Avatar
sdotk
I unplugged my HDMI and plugged it back in and all of a sudden it stopped working
Old Jul 8, 2015 | 06:30 PM
  #51
rx11fan's Avatar
rx11fan
I want to try this on my new 15 ES300h. So this will only work with parking brake on? I too bought that hdmi2av box with usb power for my other infiniti and haven't tried it yet. Infiniti has RCA input while the lexus uses that 4pole input. Anyone got the brake/speed override for this setup?
Thanks!
Old Jul 15, 2015 | 02:21 PM
  #52
rx11fan's Avatar
rx11fan
I bought the apple lightning digital AV cable and teh hdmi-RCA w/ usb power from ebay and used a camcorder cable (RCA-AVoutput) and it worked like a charm. Forgot to press the brake pedal and had to use red to yellow jack on the rca connector and the cable. Now, did anyone succesfully install something that would bypass the parking brake and speed sensor restriction? It would be damn nice if we could use google maps from our phones...
Old Jul 15, 2015 | 05:58 PM
  #53
Kwik8276's Avatar
Kwik8276
Default A/V Input Instructions
Yeah , but the bestsonic dvd bypass module !!!
Old Jul 16, 2015 | 07:34 AM
  #54
rx11fan's Avatar
rx11fan
Is this the one? Thanks.
http://www.beatsonicusa.com/tvk-62.html
Old Jul 16, 2015 | 08:47 AM
  #55
sdotk's Avatar
sdotk
This is the one
http://www.beatsonicusa.com/bb6223.html
they are actually a sponsored vendor, you should find them and PM them.
Old Jul 16, 2015 | 10:00 AM
  #56
rx11fan's Avatar
rx11fan
Originally Posted by sdotk
This is the one
Thanks. I will call them. I thought the one you listed was if I had a navigation system. I don't have a NAV on my 15' ES300h.
Old Aug 24, 2015 | 11:17 AM
  #57
starbai's Avatar
starbai
Originally Posted by Scar170
I tried switching around, but that didn't work. I'm guessing the 4th pole on the AV cable I have (near the base) is ground, so switching around the cables didn't work. Btw, thanks for the tutorial!
Originally Posted by gennacide
try a different 4 pole to composite cable then
So it seems that the 4 pole end, the 2nd from the tip or 3rd from the cable itself, needs to be ground, but most I'm finding, have the one closest to the cable (4th from tip) as the ground.
Old Aug 24, 2015 | 11:22 AM
  #58
Answer's Avatar
Answer
I previously posted the exact pinout needed
Old Aug 24, 2015 | 12:23 PM
  #59
starbai's Avatar
starbai
Has anyone tried this?
http://www.prestigioussociety.com/?page_id=1223
I understand its more expensive than a few cables but I wonder if perhaps its not necessary to do a vehicle in motion bypass to be able to use the the dash screen to mirror the iphone screen with this?
Old Aug 24, 2015 | 12:25 PM
  #60
starbai's Avatar
starbai
you did, thank you. Just that its hard to find the exact order of what each part is when looking... on amazon for example. and its seems when i do find a cable with the specs listed, the portion closest to the cable itself is almost always ground, not 2nd from tip.
