A/V Input Instructions
Old Jan 10, 2017 | 12:37 PM
  #106
GSBLKBLK's Avatar
GSBLKBLK
Originally Posted by badbwoy007
So I received 2 of the 3 items today. Still waiting on the hdmi box.
I decided to give the a/v cable a try since that has been the issue for most people.
Plugged it in and.... jackpot!
Did you use a coupler? Or just the 3 wires on that specific cord? Having issues with my HDMI-AV input... Returned my cables I already bought and bought these above. Hoping it works.
https://www.clublexus.com/forums/gs-...ml#post9732863
Old Jan 10, 2017 | 12:44 PM
  #107
badbwoy007's Avatar
badbwoy007
I used a coupler on the test I did last night.
Old Jan 10, 2017 | 12:47 PM
  #108
GSBLKBLK's Avatar
GSBLKBLK
So if I'm going from HDMI-AV, whis has female AV output, I need a MALE/FEMALE coupler right??? See attached
Attached Thumbnails A/V Input Instructions-20170110_134713.jpg
Old Jan 10, 2017 | 12:49 PM
  #109
badbwoy007's Avatar
badbwoy007
No coupler needed. You just need the right 3.5mm jack, and your HDMI cable to connect to whatever you plan to use.
Old Jan 10, 2017 | 12:51 PM
  #110
badbwoy007's Avatar
badbwoy007
Are you getting any audio or video? Have you swapped the a/v plugs around to see if that works?
Old Jan 10, 2017 | 12:55 PM
  #111
GSBLKBLK's Avatar
GSBLKBLK
Yes just blurred lines. See picture. Getting bad feedback (audio) when the white is in the white hole, tried every single combination, then switched from PAL to NTSC, and again tried every single combination. Getting nothing close to what's on my phone, just blurred lines like the picture. I'm wondering if the HDMI to Micro USB the same thing, Fidgety, where I'll have to replace a few of them to find the right one? I got this one on Amazon....
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
And I just bought the cords you posted above, the one you said worked in 1 try.
Attached Thumbnails A/V Input Instructions-20170110_134723.jpg
Old Jan 10, 2017 | 01:03 PM
  #112
badbwoy007's Avatar
badbwoy007
Ok cool. I'd say that 3.5mm cord is the most important item that needs to work properly before adding additional components. The "wiring" of the cable has to be correct in order for it to work.
If you look at the picture below, from the cord I got, video sits on the sleeve which I believe is the way the car is looking for.
Old Jan 10, 2017 | 06:12 PM
  #113
KietV's Avatar
KietV
Registered User
This is neat. Too bad the bypass costs so much......any other options for that?
Old Jan 10, 2017 | 06:17 PM
  #114
badbwoy007's Avatar
badbwoy007
I came across this: Navigation/Video Unlock/Bypass for Lexus, Model ULM-61
Not sure if anyone on here has tried it.
Old Jan 10, 2017 | 06:37 PM
  #115
badbwoy007's Avatar
badbwoy007
So the HDMI to AV adapter came today and here are the findings.
I hooked up the unit and was able to see iPhone mirrored to the screen.
The picture quality was not that great and the audio had a buzz on the line. I took quite some time to compare all these boxes but I think the reality is that whether $6 or $26 I think they are all the same which is not that great.
So what I ended up doing was going to Radio Shack and picking up the lovely overpriced $40 no external power needed adapter. All I can say is that it is fantastic!
Here are some comparison shots below.
CINK HDMI BOX
You can see the lines in the shot
RADIO SHACK ADAPTER
Nice rich black
Old Jan 10, 2017 | 06:46 PM
  #116
badbwoy007's Avatar
badbwoy007
Default Cink HDMI to AV Box
Also wanted to show shots of the PAL vs NTSC.
PAL had a richer black screen but part of the picture was off the screen.
Here is a Youtube shot.
Overall the unit worked but I prefer something a little richer and crisper and the added perk of no external power needed on the Radio Shack cord is a great plus.
Old Jan 10, 2017 | 06:54 PM
  #117
badbwoy007's Avatar
badbwoy007
After doing some more research I decided to give it a shot in the dark.
Here are the components I decided to try:
StarTech.com 0.3m 1ft Short High Speed HDMI Cable
Cingk 1080p HDMI to RCA CVBS AV Composite Converter
Zune A/V Output Cable
Total cost was under $40. I will post the outcome after I get the products.
My revised recommendations: ~ $60
$9 StarTech.com 0.3m 1ft Short High Speed HDMI Cable
$40 RadioShack HDMI-to-Composite Converter (Highly Recommended)
$7 Zune A/V Output Cable
Old Jan 10, 2017 | 07:09 PM
  #118
badbwoy007's Avatar
badbwoy007
Default Ulm-81
On second note, I found this from the initial group buy launched by the vendor. Looks like there are people out there using it.
https://www.clublexus.com/forums/clu...-134-99-a.html
Looks like I might be looking at this lower cost option.
ULM-81
Old Jan 10, 2017 | 08:55 PM
  #119
LexSense's Avatar
LexSense
Awesome job on the research, this should help out many!
Thanks again for taking the time and expense to experiment with this.
Old Jan 11, 2017 | 07:28 AM
  #120
badbwoy007's Avatar
badbwoy007
No problem!
