Tire Pressure Gauge?
Old Sep 30, 2014 | 04:45 PM
Spagolli94's Avatar
Spagolli94
Default Tire Pressure Gauge?
Quick question. My old Acura used to tell me tire pressures at all 4 corners. It was displayed on the dash, next to the tach. Does the IS350 have a tire pressure gauge? Or does it only warn you if there is a problem?
Old Sep 30, 2014 | 04:54 PM
Mtneer's Avatar
Mtneer
My non F IS shows the pressure of each wheel on the screen between the tach and speedo.
Old Sep 30, 2014 | 05:07 PM
DreamAce7's Avatar
DreamAce7
On the new IS you should be able to see all tire pressure.
Old Sep 30, 2014 | 05:15 PM
Loe's Avatar
Loe
You can access in the gauge cluster or the center control display via the mouse pad, it will give you fairly accurate PSI readings.
Old Sep 30, 2014 | 07:34 PM
Spagolli94's Avatar
Spagolli94
Sounds great - thanks!
Dolphin
RX - 3rd Gen (2010-2015)
18
May 8, 2016 01:08 PM
daryll40
Oct 22, 2007 04:36 PM
RA40
Wheels, Tires & Brakes Forum
Dec 3, 2004 05:44 AM
MikeDC
Oct 1, 2003 11:55 AM
