Do I Need To Change My Oil Already?!
The 2011 IS we had was specced for synthetic and 10k mile oil changes. You should have no problem going 7-10k using most major brand full synthetic oils.
I've done synthetic oil analysis on 3 different cars that have over 100k miles: LX470, TSX, and a Pilot. TBN test revealed that the oil is good for about 10k miles, and even 12-13k miles on the LX
lmao! yeah i couldn't get my phone to focus on the dipstick, even when trying to adjust it. anyways thanks for the feedback guys. this forum is always so helpful. after feeling the oil it still feels fine. no sediments or anything on my finger leading me to believe its just dirty in color but viscosity and cleanliness of it is just fine.
Well, it's not like the car has a built in "oil monitor" that looks at the viscosity, TBN, etc. to determine if the oil is still within parameters like a analysis would. I hope you didn't read it that way. It has a OLM that determines oil life based on rpms, miles, temperature, etc. to determine when you should change the oil. It's not really analyzing the oil but rather analyzing the car and estimating when you should change it.
You wouldn't be able to "feel" if the oil is good anyway. If you were able to feel grit/shavings on the oil that's on the dipstick you'd be in trouble. The filter filters out particles rated in microns. although I'm not sure what microns size it filters at and to what efficiency. Something is telling me 20 microns but I'm not sure.
I don't really know how it works but would love to understand it better. The reminder light came on for the first service on my RX when it hit about 4800 miles, then the second service around 9700 miles (currently 11600 miles on the OD). The light for the first service in my IS came on at about 4200 miles (currently at 7800 miles on the OD).
Maybe the light comes on a few hundred miles before the 5 and 10k just as a warning? I know you can also customize several settings in setting>vehicle>maintenance and set oil, filter, tires, etc for miles, date, or odometer.
PS to the OP. My oil was changed 1500 km ago and looks like yours. I'd say it's normal.
Phresh2010
May 28, 2010 12:32 PM
