leak at mid car :uh
Old Sep 17, 2014 | 03:09 PM
mnm27mnm's Avatar
mnm27mnm
Default leak at mid car :uh
This afternoon I saw that car was leaking some fluid by mid car. Next to the catalytic converters. At first I thought it might be oil since I just did an oil change 2 days ago. But after taking a closer look it wasn't from the oil pan. I just want to make sure the leak is from the A/C system and not something else.
Old Sep 17, 2014 | 04:12 PM
Joe Z's Avatar
Joe Z
Exclamation
As long as its clear water... It's called condensation
~ Joe Z
Old Sep 17, 2014 | 06:15 PM
mnm27mnm's Avatar
mnm27mnm
The condensation is from the A/c system right? I usually see it towards the front of the vehicle in my other cars not the middle.
Old Sep 17, 2014 | 08:29 PM
mrkjsn's Avatar
mrkjsn
How about the oil filter? Could it be leaking? Did you touch the leak? Oily or watery?
Old Sep 17, 2014 | 09:06 PM
faisal11ir's Avatar
faisal11ir
It's the AC condensation...normal in the 3IS.
Old Sep 18, 2014 | 12:40 PM
timmy0tool's Avatar
timmy0tool
most lexus RWD cars drain the condensate near the steering rack or right behind the front wheels. if the leak is in the middle of the car (center between front and rear wheels), it's something else. mostly likely it's just AC condensation like everyone said.
Old Sep 18, 2014 | 12:46 PM
hades281's Avatar
hades281
Should be condensation, as others have said. You should be able to dip your finger into the puddle and see that it's water - colorless and not oily.
This is one reason why automobile fluids are all different colors. You can spot leaks, and it helps prevent people from putting the wrong fluid in the wrong place.
Jvgs300
May 11, 2017 01:33 PM
UGAALF
Oct 3, 2015 03:16 PM
Tom-GV
Dec 12, 2010 09:11 AM
0nePutt
Maintenance
Oct 25, 2009 02:17 AM
indypwr
GS - 1st Gen (1993-1997)
22
Mar 16, 2003 07:35 PM
