Square Tire Setup - Anyone Try This?
Old May 30, 2014 | 01:43 PM
  #31
Vairox's Avatar
Vairox
IJS lol
Attached Thumbnails Square Tire Setup - Anyone Try This?-thisthreadisuselesswithoutpics-1.jpg
Old May 30, 2014 | 01:49 PM
  #32
CJW's Avatar
CJW
Yes, we need pics.
Is there also a thread dedication only to wheels? I'd love to see some of the styles people have.
Old May 30, 2014 | 02:54 PM
  #33
JGard18's Avatar
JGard18
Where are you getting all this understeer? On the street?
I've only once experienced understeer in this car on the street and it was because I was being an idiot and totally overloaded the front tires. When you drive with an attention to weight balance/transfer, it's pretty easy to drive this car hard and keep it neutral or have it oversteer.
I'd suggest participating in autocrosses or track days to learn the car better (And how to drive better) before completely changing the dynamics of the car.
Old May 30, 2014 | 03:46 PM
  #34
Vairox's Avatar
Vairox
four 18's the same size allows rotations and they are cheaper, never liked staggered, my 350z and C6 had it and it's for looks really, this car doesn't really have the power to cause a change is dynamics anyhow the only time I could get it sideways was going around a corner in the rain and stomping the gas.
Old May 30, 2014 | 04:10 PM
  #35
redspencer's Avatar
redspencer
OG Member
Veteran: Marine Corps
+1
If you're accelerating at the start of a turn, most of the weight will be to the rear and the front tires will not have enough load to allow the car to turn properly which will promote understeer.
If your VDIM is fully engaged, the system could also be cutting back on your steering input if it senses that you might be going into an oversteer situation.
Lastly, most cars are tuned to understeer from the factory for liability reasons. In addition to a square tire set-up, you might want to look into modifying your front and rear sway bar configuration if you want to alter the handling behavior of your car.
Old May 30, 2014 | 04:56 PM
  #36
jcheng's Avatar
jcheng
Here are a few pics.
Old Jun 1, 2014 | 12:36 PM
  #37
UncleSpud's Avatar
UncleSpud
Lookin' good jcheng.
Final question: you've obviously got a lot invested in new rims/rubber. Aesthetics aside, is it worth going square for the handling benefits alone, or was the change in that regard incremental?
Old Jun 2, 2014 | 10:11 AM
  #38
jcheng's Avatar
jcheng
I only noticed a difference in handling when I switched tires from the ER33 to the V12. Much more grippier and inspires more confidence on harder turn ins.
The major benefit, and the reason I went to a square setup, was for tire rotations. If I get a flat, I don't have to worry about what tire to put where and such. I do not plan on dropping so aesthetics was the last thing on my mind.
But to answer your question... going square has no change for everyday driving. The tires make the biggest difference.
Old Jun 2, 2014 | 10:26 AM
  #39
bhvrdr's Avatar
bhvrdr
I agree on the street you shouldnt be getting any oversteer or understeer since you would have to be breaking the law to do so
For lap days I had a lot of undersired understeer. It is worse than my S4 ever was and that was a nose heavy car.
I'd love to find some sways that dont cost an arm and a leg like the TRDs. For now I am doing the best springs I can find that increase the rear spring rate which is the RSR down. We'll see.
Mike
erik535353
Wheels, Tires & Brakes Forum
Aug 9, 2021 12:29 AM
is250san
Jun 27, 2016 08:28 PM
dll5007
Jul 11, 2011 02:59 PM
KvnChu
Performance
Apr 26, 2009 10:19 PM
ALWAZEER
13
Oct 3, 2006 03:21 PM
