Led bulbs !!
Vinyl or plastic prying tools makes the job of changing bulbs very easy. All the lenses will easily comes lose with a sharp prying tool. Don't use a screwdriver, you'll scratch the lens.
Avalible at most hardware stores for about 10$..
An ebay link here:
http://www.ebay.com/itm/AUTO-TRIM-MOLDING-INSTALLER-REMOVER-PRY-BAR-TOOL-SET-/131055143491?pt=Motors_Car_Truck_Parts_Accessories&hash=item1e837eca43&vxp=mtr
An ebay link here:
The headliner bulbs are easy - use a plastic pry tool.
The footwell are also easy to remove the lens - the hose trick removes the bulbs very easy.
The trunk light (from standing looking into the trunk) the lens releases on the right side and then you need to slide it to the right to remove. The left side slides under the trunk liner - clips / 'prongs' are on the right side only.
The reverse lights (#921 bulb) is best removed after removing the trunk liner. A clip removal tool is best used here. I replaced with the Sylvania 6000k bulb (found these at Pep boys @ #30.00ea with a coupon - reg. $35.00ea). These had to be inserted being mindful of polarity. If they don't light up, remove and rotate and then re-install. Test before re-installing the trunk liner.
We have LED packages for the 2014 Lexus IS that starts under $100.00. We have LEDs that are super bright and also ones that are more subtle (better than factory bulbs but not too bright).
Just send us a private message or email and we can do a custom LED package based on your personal preference.
Cheers!!!
Kenneth
HID Powerhouse
Cheers!!!
Kenneth
HID Powerhouse
talwang
RX - 3rd Gen (2010-2015)
33
Mar 24, 2014 04:52 AM
MA Cree 921 LED
bigblack06
Jan 25, 2013 07:23 PM
ashley1977
Sep 24, 2012 05:58 PM
