Cruise Control cut-out
Old Dec 21, 2025 | 09:23 AM
pab12's Avatar
pab12
Default Cruise Control cut-out
Twice in the last couple of weeks my cruise control has cut-out while driving. Both at night in cold sleet.
The first time I felt the car go out of cruise and saw note on the speedo saying something like "cruse control not available." I shut the cruise off and drove home. There were no problems after that until Friday night.
That night, again, the cruise shut down. I drove manually for a while and then turned it back on, and it set correctly.
Shortly afterwards, however, I got a bright yellow note in the middle of the speedo telling me that the emergency forward braking was not working, along with something about the radar speed sensor. There was also yellow warning light showing on the right side of the speedo. I shut it off and drove home manually.
Again the next day everything was fine and I was able to use cruise while driving through town.
I will make a service appointment to have it looked at. But I'm wondering if it set a yellow warning light (that is now off ...) did it also throw a code that the shop will be able to see?
Old Dec 21, 2025 | 10:16 PM
kj07xk's Avatar
kj07xk
You said it happens when driving in sleet. I suspect the radar sensor area gets covered with a layer of ice that is too thick for the sensor to work properly.
Have that issue with the front parking sensors going off while driving in sleet or a sloppy snow storm. When I get to my destination, the front end is all iced up.
Old Dec 22, 2025 | 06:45 AM
mcomer's Avatar
mcomer
Excerpt from TIS from IS 350 cruise control section:
If either of the following conditions occurs, the ECM cancels the cruise control while retaining the set vehicle speed in its memory.
1) The wipers operate at HI speed.
2) The measurement becomes extremely unstable due to poor weather conditions.
Cruise control is prohibited until the normal operating conditions are met or the cruise control system is turned off and back on again using the ON-OFF button on the cruise control switch.
Old Dec 22, 2025 | 10:31 AM
pab12's Avatar
pab12
Excellent, thanks.
But what about the yellow message and warning lamp? Do you think the car threw a code that the dealer could see?
comotiger
Sep 12, 2016 08:46 PM
puckhead85
Mar 29, 2014 07:01 PM
09RX350AWD
Jan 14, 2010 03:31 AM
pinoyballa
RX - 1st Gen (1999-2003)
Aug 31, 2009 03:50 PM
mr29rose
Dec 25, 2008 05:10 PM
