Fix for C2126 TPMS code?
Old Oct 19, 2025 | 05:19 AM
NimR's Avatar
NimR
10th Gear
Default Fix for C2126 TPMS code?
Hey guys,
Just put new Tyres on all four corners and got an alignment done with new TPMS sensors installed. I asked the shop to program the sensors for the car and when I picked it up no TPMS light was on the dash. When on a 20+ minute drive two days after and lo and behold the TPMS light came on blinking 1+ minute and stayed on. Scanned it and the code is C2126 : Transmitter ID not received main mode. And the sensor readings are at ‘N/A’ on live data. Do you think I have to get a proper TPMS programming tool to fix this? Thinking about getting an Autel MaxiTPMS (TS508WF) to fix it? Just wanted to know anybody had a similar experience.
Cheers
Car: ‘14 IS350 F-Sport, Australian model
Old Oct 19, 2025 | 06:31 PM
Mc44's Avatar
Mc44
The shop likely didn't properly register the new sensor IDs to the car's ECU. A C2126 code means the car is looking for the old sensors. A proper TPMS tool like that Autel is exactly what you need to fix it yourself. It's a common issue after sensor replacement.
Old Oct 19, 2025 | 06:59 PM
NimR's Avatar
NimR
10th Gear
Thanks for the reply mate. I’m waiting for the TPMS tool to be delivered. Will update after I attempt to get it fixed.
Cheers
Old Oct 24, 2025 | 11:51 PM
NimR's Avatar
NimR
10th Gear
Hey mate,
The code is still there. Kind of wondering whether my new sensors are the proper frequency. Got the 315MHz ones and my key fob frequency is also 315 MHz. Did the relearning procedure with the Autel but the C2126 code is still there. The Autel verifies the Sensor IDs are matching with the ones stored in the ECU as well. Kind of hit a wall here.
Should I replace them with 433MHz ones?
Old Oct 25, 2025 | 04:51 AM
kj07xk's Avatar
kj07xk
That’s a good question. On my other car, 315MHz is used in the US, while 433MHz is used in Europe.
So I just asked ChatGPT, and it says that 433MHz is used on your Australian spec’d car.
Old Oct 25, 2025 | 09:25 AM
NimR's Avatar
NimR
10th Gear
I found mixed information about the frequency when I was looking for the sensors. Many sources said it is usually the key fob frequency. Will post an update when I install the new set of sensors.
Old Jan 7, 2026 | 01:00 AM
NimR's Avatar
NimR
10th Gear
[UPDATE]
Hi guys,
Replaced the TPMS sensors with 433MHz and after reprogramming TPMS light and the DTC went away.
Cheers
wayman28
Aug 18, 2025 12:51 PM
Stedman
NX - 2nd Gen (2022-current)
15
Jun 26, 2023 02:19 PM
bladest
Jul 31, 2022 01:42 PM
Krishna108
Hybrid Technology
Oct 4, 2019 08:15 PM
ubersonic
Nov 4, 2015 01:00 AM
