I have the 2023 Is 350 F sport awd with the staggered wheels. I decided to switch to a square wheel set up for winter tires. I put on 19X8 Sparco DRS rims with a 245/35R19 93W winter tire. The whole car has a vibration now. The tires are balanced and the alignment is not off. How do I fix this?
kj07xk
close
- Join DateJan 2016
- LocationIL
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:416 Times in 327 Posts
Try a different shop for balancing. I’ve been very happy with a local Discount Tire shop that does Road Force balancing. They showed me that a tire was actually ‘out of round’, clearly visible with the wheel&tire spinning on the machine.
arentz07
close
- Join DateNov 2016
- LocationGA
Liked:4,801 Times in 2,374 Posts
+1. Sometimes road-force balancing makes the difference. Had a friend who had a similar issue on his car with new tires - turns out the mobile tire installer didn't have the capability to do a road-force balance, so he needed to take it into a shop. After that, the problem was solved.
1squirrel
close
- Join DateJan 2018
- LocationKansas
Liked:19 Times in 16 Posts
Are the wheels you put on hub centric? If so, are they the correct size to fit the Lexus hub? If not, you probably need centering rings to make sure the wheels are centered.
Quote:
This was my initial thought too.Originally Posted by 1squirrel
I will say, I have had to have wheels rebalanced a few times. I would have them checked. Another echo for road force balancing.
Quote:
This. Lexus bore size is usually 60.1 and I believe DRS is 73.1. Originally Posted by 1squirrel;[url=tel:11850822
11850822[/url]]Are the wheels you put on hub centric? If so, are they the correct size to fit the Lexus hub? If not, you probably need centering rings to make sure the wheels are centered.
If it isn’t the wheel ring adapters I’d look maybe at the rotors or if the lugs are overtorqued
