intercooler fluid change?
Old Dec 17, 2024 | 09:19 PM
davyjordi's Avatar
davyjordi
Default intercooler fluid change?
hi guys,
k, so i'm pretty religious on changing fluids and while my car only has 29k miles, it's a 2020, so today i had the transmission drained and filled, as well as the differential, and brake fluid, spark plugs, and air filter changed. oil changes are every six months as i never reach the 5k milestone before then.
most importantly right now, should i have the intercooler fluid changed?
are there any other big wear items that i need to give attention to? serpentine belt? visual inspection was okay, but i don't know the lifespan given that the car is five years old at this point. regular coolant/antifreeze? what about the fuel filter? do i just use fuel cleaning additives like chevron's techron concentrate to maintain the fueling system?
am i missing anything? this car needs to last for some time because my previous IS was totaled -- so sad -- and the insurance was awful with the payout.
thank you!
Old Dec 17, 2024 | 11:04 PM
NYIS300awdFS's Avatar
NYIS300awdFS
Originally Posted by davyjordi
hi guys,
thank you!
Guessing your car is a 4 cylinder turbo, intercooler has fluid ? Blow by oil ?
Clean any oil out of the intercooler and charge pipe. If you haven’t yet, spray the maf sensor clean and clean the throttle body. Another thing I like replacing on engines is the pcv but your engine still has low miles. Cabin air filter every year, and always use good premium fuel.
Old Dec 18, 2024 | 05:45 AM
davyjordi's Avatar
davyjordi
yeah, it's the inline turbo four. the turbocharger itself has a coolant reservoir that isn't fed by the main coolant system.
thanks for mentioning cleaning the others. i'll look for youtube videos on how to clean the intercooler and charge pipe. i had forgotten about the maf sensor and throttle body.
thanks!
allarmees
Hybrid Technology
Nov 22, 2024 06:08 AM
mtbiker78
Sep 3, 2019 11:38 AM
mike430
May 16, 2015 04:51 PM
Im2nyc3
Dec 6, 2012 06:13 AM
Gekko
Maintenance
Mar 3, 2003 02:50 PM
