What is the interval for front and rear differential fluid change?
Old Nov 30, 2024 | 03:02 AM
Clueless33's Avatar
Clueless33
Default What is the interval for front and rear differential fluid change?
Hello everyone! Hope all is well.
My 2018 Lexus IS 300 AWD FSport is nearing 70,000 miles and the maintenance log I’m looking at right now says to inspect front and rear differential oil at 90,000 miles but nothing about when the oil should be changed.
The transmission was flushed at the Toyota dealership in October at 67,000 miles and the car’s performance has improved tremendously as a result, with smoother gear shifting and responsive shifting.
I plan to flush the transmission again around 110,000 miles.
The reason I chose a flush ( fluid exchange ) over drain and refill was because the professionals over at CarTalk.com, and some of the guys on this platform, highly recommended it. A fluid exchange is safe when done early ( around 60,000 miles ) rather than later they warned.
Now, I would appreciate your insight on when the front and rear differential oil on the Lexus IS AWD needs to be changed.
As always, thank you very much for your time and knowledge-sharing with me today.
Clueless33.
Old Nov 30, 2024 | 12:35 PM
NYIS300awdFS's Avatar
NYIS300awdFS
I had mine done at 60,000 miles but will probably go to 45,000 mile intervals from here on.
Old Nov 30, 2024 | 06:08 PM
Clueless33's Avatar
Clueless33
Do you mind sharing why you will be doing it at 45,000 miles from now on ? And did the dealer recommend it for 60,000 miles?
im asking because the user manual is mute on the issue and I don’t understand why.
Old Nov 30, 2024 | 06:20 PM
NYIS300awdFS
I purchased the car with 58,000 miles without complete service history. I plan on holding on to the car long term. The 60,000 mile service recommends checking front and rear diff oil. Might as well drain it and replace it, same with the transmission as preventive maintenance.
Old Nov 30, 2024 | 06:33 PM
ckoolen's Avatar
ckoolen
7th Gear
I plan on sticking to 60k intervals
Old Nov 30, 2024 | 07:39 PM
Clueless33's Avatar
Clueless33
ok. So I’m going to request this service for my 70,000 miles maintenance service.
Old Nov 30, 2024 | 07:42 PM
60K on a manual transmission produces fluid that has seen better days, not a direct comparison but maybe a useful data point.
Hues10
Aug 26, 2025 06:27 PM
Ozzy1980
Oct 28, 2016 02:19 PM
wes77
RX - 3rd Gen (2010-2015)
Sep 30, 2011 06:57 AM
MJB_LEX
Sep 11, 2007 01:19 PM
UberNoob
Maintenance
May 12, 2006 03:27 PM
