Can't program TPMS sensor
Old Nov 28, 2024 | 11:55 AM
Ruzifan's Avatar
Ruzifan
Default Can't program TPMS sensor
I just bought a TPMS sensor from lexus. i have the Autel 501. my old sensor can scan no problem. so i used the Activison by Code, and it can't read the new sensor. It says no sensor found. Is there something else i have to do?
Old Nov 28, 2024 | 01:39 PM
lexo98's Avatar
lexo98
I’ve never used the autel but for an oem sensor it should scan in a normal mode. No need to activate or program. Sounds like the option you are using is to register the tool
Old Nov 28, 2024 | 07:37 PM
kj07xk's Avatar
kj07xk
Has the sensor been installed in the wheel? Or is it just sitting on your bench? If the latter, some sensors (I don’t know about the OEM ones) require a trigger signal to activate them.
Old Nov 28, 2024 | 08:48 PM
dwoods801's Avatar
dwoods801
Is the new sensor activated? Do you have to install the battery or press a reset switch or something?
Old Nov 29, 2024 | 03:19 PM
Ruzifan's Avatar
Ruzifan
Weird, I installed it on the tire, and sensor read it fine. Just had to do obd relearn
tucker21
May 19, 2016 05:26 PM
EJ255t
Mar 7, 2015 04:06 PM
redrocks
GX - 1st Gen (2003-2009)
Feb 12, 2014 05:47 PM
GQis350
Aug 26, 2012 08:35 PM
