Intermittent (Fuel Pump??) Issues.
Old Nov 9, 2024 | 01:22 AM
miamiblue350's Avatar
miamiblue350
2nd gear
Exclamation Intermittent (Fuel Pump??) Issues.
The car will start up and drive just fine until you shut it off (you have to drive it until it gets hot i presume because this issue will not occur if you drive it for short periods or when it is cold outside and sometimes you have to drive it for hours for it to occur), once you shut the car off and turn it back on it will idle fine for about a minute or so then slowly will start to misfire and idle rough,after a few minutes the misfires and rough idling gets worse (it will eventually kick a code after the misfiring ramps up slightly)until the vehicle stalls.You are not able to start the vehicle for multiple hours(sometimes it will start up about 30 mintues later but it really depends).Once the car will eventually start back it runs fine until you shut it off again and then the problem persists.We are getting multiple codes with our scanner.Codes P0191,P0171,P0174,(P107B??)P0301,P0302.This issue has been going on for about a year and we have not been able to fix it, have done multiple things to try to remedy the issue ie: replacing both fuel pumps (there was a recall on one of them that we got done)swap around relays,Vehicle starts up just fine, you can drive it for a little while and then shut it off.I have done alot of research on this issue and I have narrowed it down to a couple things, Fuel pump driver module, Fuel pressure regulator,or Fuel pump relay(maybe crank position sensor dont really think so though.).This has been a thorn in my side ever since we purchased the vehicle and it is really unfortunate because it is such an amazing car and i do not want to sell it! Thank you.
2018 IS 350 F
Old Nov 10, 2024 | 09:48 AM
arentz07's Avatar
arentz07
Have you replaced spark plugs? What mileage are you at? Are there any other codes besides the ones you listed?
Old Nov 10, 2024 | 11:29 AM
miamiblue350
2nd gear
No i have not replaced plugs, im at 60000 miles.those are all the codes I recall.
wouldnt think it would be plugs because its running too lean.
Old Nov 11, 2024 | 06:24 AM
snowyblue's Avatar
snowyblue
Old Oct 26, 2025 | 09:03 PM
Dyl16211's Avatar
Dyl16211
1st Gear
Were you ever able to figure out the problem ?
volvodude
Apr 25, 2021 12:09 AM
OHLexusFan
Jul 27, 2019 06:35 PM
tomtheslac
16
Sep 9, 2010 07:45 PM
ta1972
Nov 8, 2007 11:38 PM
na4now
Aug 10, 2007 12:29 PM
