IS 500 brakes
Old Oct 27, 2024 | 07:40 PM
ricoyalda's Avatar
ricoyalda
7th Gear
Default IS 500 brakes
Does anyone know if the IS500 brake rotors and pads will fit on a 2022 Lexus is 300/350?
Old Oct 28, 2024 | 06:18 AM
arentz07's Avatar
arentz07
Which wheels are on your car?
Old Oct 28, 2024 | 07:32 AM
ricoyalda's Avatar
ricoyalda
7th Gear
currently the stock 235/45/R18 if i upgrade to bigger wheels they will fit? or they can fit in these sizes
Old Oct 28, 2024 | 07:36 AM
arentz07's Avatar
arentz07
The reason I asked about the wheels specifically is because the wheels need to have the right offset to clear the calipers. The stock F Sport 19-inch wheels are known to work with the IS 500 brakes, as we have a member who swapped the IS 350 wheels onto his IS 500. Now, I am not sure about 18-inch wheels - they will probably work, as I think the calipers are basically the same size between the IS 500 and IS 350 - the main difference is in the rotors, which are larger on the 500. Both have 4-piston calipers up front. Rear brakes are obviously not an issue.
So, I'd love to just say yes, but I don't know if anyone has tried it before. It will probably work though. Not sure if you could do a test fit?
Old Oct 28, 2024 | 03:00 PM
ricoyalda's Avatar
ricoyalda
7th Gear
okay i don’t mind about the wheels as i am getting 19 inch wheels later on, i was just asking because i thought the calipers between the 300/350 and 500 were different as they do have a different appearance
Old Oct 29, 2024 | 07:11 PM
arentz07's Avatar
arentz07
Oh I know they're not technically the same brake caliper - I have owned both an IS 350 and IS 500, and the difference is obvious. But they are both four-piston calipers and look to be roughly the same size.
Old Oct 29, 2024 | 08:28 PM
InveredMP's Avatar
InveredMP
I wouldn't change to IS500 brakes unless you find calipers cheap. Really no point. Just go ISF or GSF.
Old Oct 30, 2024 | 10:10 AM
arentz07's Avatar
arentz07
Right, I forgot to mention this - the benefit to upgrading to IS 500 brakes is probably not worth the effort/money. They're still 4-piston, just slightly larger rotors as well as two-piece rotors up front.
Old Oct 30, 2024 | 12:13 PM
ricoyalda's Avatar
ricoyalda
7th Gear
yeah i was thinking about upgrading to is 500 pads and rotors so i wouldn’t have to change calipers. But i guess spending more money for the 6 piston gsf/rcf brakes are better
Ebabe
Aug 30, 2023 10:53 AM
rxy77
Suspension and Brakes
Jan 29, 2023 12:39 AM
websurfer
Nov 5, 2022 12:38 PM
clintong
Nov 1, 2021 01:30 PM
Kharizma
Wheels, Tires & Brakes Forum
Dec 6, 2005 08:34 PM
