Stuck lug bolt
Old Oct 7, 2024 | 12:41 PM
sean101112's Avatar
sean101112
Default Stuck lug bolt
Hello everyone, one of my lug bolts is stuck and will not move. I put them on started by hand and torqued to 103 lbs-ft, I rotated my wheels only 2,000 miles ago. I have tried pb blaster, impact gun, breaker bar with a jack handle over it, does anyone have any tips I plan to just bring it to my shop I do not want to break the bolt and have a bigger issue. Thank you guys for your help!
Old Oct 7, 2024 | 06:15 PM
kj07xk's Avatar
kj07xk
Maybe the only thing you haven’t tried is heat. If you can quickly heat the nut and not the bolt (like with a torch, but not damage the wheel’s finish), then try the breaker bar again.
Old Oct 7, 2024 | 07:49 PM
Oro's Avatar
Oro
Heat. Let it cool, then use a long lever arm on the breaker bar. Slip a long pipe over the end of the breaker bar, or improvise something like that (I use a 3’ tow bar), and apply more torque judiciously.
Old Oct 10, 2024 | 06:26 AM
spielnicht's Avatar
spielnicht
Had the same happen to me (but with a lock bolt) and heat was the only way. Most "tire" shops are able to do this for you, but they don't take much precautions to protect the wheel itself from the heat. If you want to do it yourself, get the yellow torch kit from Home Depot (cheaper blue kit isn't good enough), layer multiple sheets of aluminum foil around the wheel bolt to protect the wheel, and go to town as mentioned by the above responses.
Old Oct 10, 2024 | 06:45 AM
Basil55's Avatar
Basil55
10th Gear
The best heat protector I found is the black felt like material from Home Depot. It is used as heat protector in plumbing welding and can be found it that section. It is 10x10 inch sheet. It stands to direct flame and is barely warm on the other side
Carbuff2
RX - 5th Gen (2023-present)
26
Apr 21, 2024 07:23 AM
1013mm
Wheels, Tires & Brakes Forum
Feb 5, 2010 06:47 PM
81corolla
RX - 1st Gen (1999-2003)
Jan 7, 2009 12:25 PM
TwentyTen
Sep 14, 2004 06:32 PM
TBONE1904
16
Apr 15, 2004 01:22 AM
