IS 200t throttle lag
THe turbo is a drag. Until the engine generates enough waste flow to push the weight of the turbine the PSI is negative. So I believe a huge chunk of the IS200T's fuel is lost on initial
from Stop to Cruise movement. THe turbo does not help at all in this regard and is a detriment to fuel economy.
I own a 2002 Subaru wrx, I’m new around here, Subaru wrx driver since 2006. Those turbo 2L engines are laggy off the line and do require knowing how to apply throttle, can’t just stab the gas pedal. The other thing I’ve learned is that turbo engines have a lot of plumbing and vacuum leaks can cause a big headache. Sounds like you are not the original car owner nor know the service history. I think you said the car has 70,000 miles, have you looked at what service your car requires at 60,000 miles ? Try to get your car service all up to date, you may find the issue while at it. I can tell turbo Subarus get unhappy from something as simple as the air box not been properly sealed. I spray clean the maf every other oil change and check the air filters every oil change. If your car wastegate is not working properly it’ll definitely cause driveability problems. Curious to hear what the fix will turn out to be, I was considering a 2017 300 rwd before I found and purchased my 2017 300awd.
Good luck.
@Pacman1193 I'm good, don't worry. I got the D3 Tune + SprintBooster and it's just fine. Prior had RaceChip + SprintBooster. I like to drive fast but also in my city, lots of people are driving fast and the stock lag from the accelerator was actually dangerous, there are situations when you really need to engage. And because the traffic is full, you get one chance. And to be honest my former car was faster at launch so that's why I did these mods. Nobody wants their next car to be worst than the old one.
@harishd1998 Please let us know if you have an update. Other people might benefit from this experience.
Yri
Nov 12, 2021 07:23 AM
HanaleiISF
Jul 14, 2017 01:02 PM
Meraki Autoworks
IS F (2008-2014)
23
Mar 27, 2015 03:29 AM
