Lift points on 2023 is 350?
Hi yall I couldn't find the 4 lift points in the manual for the 2023 IS 350. It just has the jacking points. Can someone direct me to a diagram or tell me where the lift points are? My shop will be doing some exhaust work so I want to be sure they don't lift it in the wrong spot and break some plastic under the car or the side skirts. Thanks in advance.
If that’s the case, then you need to make sure the shop has, and uses, pinch weld adapters, to not crush those pinch welds. (I use them when lifting my own car, basically hockey pucks with a slot in them.) A legitimate question, as my other car has both pinch weld jacking points, and specified lift points.
