VLAND headlight Install Issue
Installed new Vland (https://www.ebay.com/itm/394335057057) but only low and high work. When I do indicators the headlight flash. Inside console have L and R indicator slightly lit. I contacted the seller and vland but was wondering if anyone else ran in to any issue w/ these lights.
Yes, I had older aftermarket dlr headlights and had wire to the fuse box. Placed new headlight to the same location. The dlr don't do any startup animation and stays blue (unless i remove a relay in its wiring). I get no amber turn signal at all. The weird part is that I installed older headlight and the issue is the same. Indicator flash headlights. Have an appointment w/ dealer to scan the codes this week.
where did the ground wire screw into? Was it at the point that’s behind/below the headlamp?
on driver side - it was already screwed to the chassis under the light it self. I had used it to ground older DLR line to it. (New VLANDs don't have this extra wire to ground) Seems I did not tighten the screw when I took that wire out.
