2007 -MAF sensor fault code PO102
Old Nov 7, 2022 | 03:08 AM
KrugeIS250's Avatar
KrugeIS250
8th Gear
Red face 2007 -MAF sensor fault code PO102
Hi
I please need assistance with the MAF sensor - first clean the old sensor with the Air flow sensor cleaner, but the code still appears, I did replace the sensor with a new Denso unit, but the error still appears after I reset all codes.
What could be the course, or what is the next step to test or check to rectify fault code error
Old Nov 7, 2022 | 04:53 AM
geko29's Avatar
geko29
Moved to 2IS forum.
Old Nov 7, 2022 | 05:11 PM
RA030926's Avatar
RA030926
i think you may have a pin that's not getting a good connection.
Old Nov 8, 2022 | 03:30 PM
MikeFig82's Avatar
MikeFig82
When is the last time the air box filter changed? Like mentioned above check for bad cables, or pins.
lexlude
Mar 6, 2016 08:09 PM
richonline
RX - 1st Gen (1999-2003)
Nov 11, 2010 05:11 PM
hyhflo
Dec 28, 2008 06:29 PM
gazi001
Sep 10, 2007 08:10 PM
GoldieLex
Aug 8, 2005 07:57 PM
